First post, by Boohyaka
Hey, anyone with experience and recommendation for a simple 2 PC's KVM? I'd be hooking two DOS/Win98SE computers to a CRT screen and using USB keyboard and mouse, no need for sound, network or anything else, just VGA+2 USB.
I only used KVM's at work many moons ago and for managing servers they were fine, are they acceptable for fast gaming in terms of video and input latency? Are some models better than others?
Thanks! 😁
Reply 1 of 6, by Cyberdyne
Most KVM switches are just that, electronical semiconductor switches of wires. So no latency. Only with VGA, the analog signal can degrade, and that is also mainly because of longer cables.
Reply 2 of 6, by Boohyaka
Allright I get you, makes sense! I guess I'll go with that one then, it's pretty cheap, I'm not taking huge risks there:
14016305_a_123.jpeg?impolicy=ProductTileImage&resizeWidth=1399&resizeHeight=1399&resizeType=downsize&quality=high&cropWidth=0&cropHeight=0
Reply 3 of 6, by kaputnik
In my experience, Aten is always a good choice. You probably won't be disappointed 😀
Reply 4 of 6, by andrea
Boohyaka wrote on 2020-09-18, 09:43:
Allright I get you, makes sense! I guess I'll go with that one then, it's pretty cheap, I'm not taking huge risks there: […]
I have one of these, different brand but looks the same. A nice thing about it is that the USB ports are dumb passthroughs with no smarts involved. This allows you, assuming you have dual standard USB/PS2 compatible devices, to use them as USB on one computer and as PS2 on the other using only dumb adapters.
Reply 5 of 6, by Boohyaka
That's good info and good to know, thank you!
Reply 6 of 6, by kalohimal
I'm using one of these. Good thing about it is that it can run off from USB from any hosts, and no external power brick is needed. And it's cheap too.
The attachment kvm usb.jpg is no longer available
Slow down your CPU with CPUSPD for DOS retro gaming.
