First post, by minipulator
Hello all, I'm having problems getting Gabriel Knight 2 to work under DOSBox.
I have successfully installed the game after finding the -t cdrom mount option. I keep the CD mounted as one drive and the harddrive installation point as another. I run the game, as instructed, from the HD mount point, but I get a terrible hissing inside the game instead of any music or sound effects.
I have only one option to choose from, sound-wise, in the audio configuration section of install.exe (sound blaster).
I have seen the DVD installer, but I cannot use that as I am running this under DOSBox for Mac.
Anyone run into this?
Thanks ahead of time,
Minipulator
Reply 1 of 3, by avatar_58
How many cycles do you have set? I'm thinking maybe its running too slow for it to function correctly. Other than that I've not experienced this issue.
Reply 2 of 3, by minipulator
Actually, I have it set to around 5k or 5.5k. Any higher and the audio, distorted though it is, gets choppy.
My situation has changed. I am now back to using Windows. I shall try the magic hd installer and see what happens.
Thanks for the response
Reply 3 of 3, by HoustonDragon
Somewhat non-DosBox related, but there are now XP patches for both Gabriel Knight I: Sins of the Fathers and Gabriel Knight II: The Beast Within. You must have the original installation CDROMs for these to work.
Gabriel Knight XP Installer:
https://gkpatches.vogons.org/download.php?fil … etupGKXP103.exeEnglish (1.48 MB)
Gabriel Knight 2 HD/DVD Installer:
https://gkpatches.vogons.org/download.php?file=setupgk2.exeEnglish (1.34 MB)
https://gkpatches.vogons.org/download.php?fil … =istallagk2.exeItaliano (1.82 MB)
https://gkpatches.vogons.org/download.php?fil … talliertgk2.exeDeutsch (2.70 MB)
