First post, by aries-mu
Hi again.
For MS-DOS 6.22 and Win 3.11 systems (Pentiums 60, 90, and 166 MMX):
1) What SATA PCI card between Silicon Image 3114 S-ATA and Promise Fasttrack SATA150 TX4 ?
2) Will those cards work with SATA-III SSDs?
3) Would a large SSD (like 60 GB or 120 GB) be usable under MS-DOS 6.22 leaving the rest of its space non-partitioned?
4) Would I be able, just in case, to use more than one SATA port to connect 2 SSDs and set up a dual boot MS-DOS / Windows 95 / 98 / NT 4 ?
Thanks!
They said therefore to him: Who are you?
Jesus said to them: The beginning, who also speak unto you
"physical media trumps cloud-simp servitude" (Conrad Riker)
Computers should be fun inside not outside! 😉 (by Joakim, VOGONS)
