First post, by darry
Whenever I try to record anything from either the EMU8000 or line in in Windows, I hear a constant very low volume tone (will attach sample soon) in the recording . This is not heard on line-out, no matter what I unmute . Nothing is connected to the line-in jack . The issue is present when recording the input corresponding to EMU8000 even when no MIDI is playing .
This is not hum due to a ground loop (occurs when recording internally and higher frequency than 60Hz).
Anybody had that issue before with an AWE64 ? My guess is the that either the ADC, the mixer chip, or something related is going bad or is it simply a crappy design that picks up noise ?
