Gateway 2000 486 PSU
First post, by lilhoser
I'm building a retro gaming PC starting with a Gateway 2000 486/33 case and AT motherboard. This Gateway case has a structure that requires the power connector to be located beneath the fan:
https://imgur.com/guWLi4k
I bought a "used but tested" Power Tronic TK 4230DC taken from a Gateway 2000 486 tower that fits perfectly (pictured above), but the fan doesn't turn when powered on. It appears to power devices fine, however. Can I replace this fan, if so, can someone link some instructions and a place to buy the fan?
I can't seem to find many PSUs online that don't have the power connector beneath the fan, including the StarTech AT PSU mentioned in various Vogons threads (which has been discontinued anyway). Does anyone know where I can find this style of PSU?
Also, I have a second power supply from a different Gateway 486/33 system I'm working on. It's an Astec AA 14500: https://imgur.com/lB8oGd8 This unit is quite dead (sputters briefly then turns off), but these old units with switches on the side are hard to find. I was thinking someone on this forum might be interested in repairing it for me, for a fee!
Reply 1 of 6, by lilhoser
Here is a picture of the internals of the Astec (I think it's an XT PSU):
https://imgur.com/ZQ5b3lZ
I don't see any blown caps.
Reply 2 of 6, by Doornkaat
This looks like a full size AT PSU to me.
I doubt you're going to find a new one anymore but there's usually enough space in there to hack the innards of an ATX PSU into one.
I also think I mostly misread the thread.
You can measure the fan's voltage with a multimeter (I assume it's 12V) and simply swap a fan of the same voltage and physical dimensions into it. You can reuse the old fan connector cable by either cutting it and soldering the wires to the corresponding wires on your new fan or unsoldering the old cable from the old fan and resoldering it to the corresponding pads on your new fan. It's pretty self explanatory.
Reply 4 of 6, by Doornkaat
Yeah, sorry I didn't pay attention reading at first and subsequently messes up that post.
The Power Tronic looks standard full size AT to me. I mentioned that in regards to the "structure that requires the power connector to be located beneath the fan".
Both PSUs can probably be hacked to accept the innards of a new ATX PSU.
Reply 5 of 6, by lilhoser
Got it. That sounds like a project. Is there a good thread on troubleshooting a "dead" PSU? If it's not a complex task, I'd like to repair the Astec.
Reply 6 of 6, by Doornkaat
I don't think there's such a thread - plus usually I'm all pro diy repairs but in this case I would advise against it:
-If one part in a power supply failed there's an increased probability of other parts having degraded or being close to failing. Worst scenario on a PSU is the loss of all hardware connected. If you need a guide on how to troubleshoot a PSU you are likely not able to thoroughly check the components.
-Also if you need a guide on troubleshooting a relatively simple PSU I can only assume you're an electronics beginner. It is probably best to start practicing with circuits that do not connect directly to mains voltage.
I would suggest to instead look for a retired technician or somebody similar who will guide you through the process for a sixpack of beer. Maybe there's a hackspace or a repair cafe near you with people that'll also be able to help you and teach you.
This is just my two cents, I don't mean to be a dick and I can only make assumptions based on what little I have read from you. If I'm wrong in my assessment or you simply want to do it yourself anyway I won't tell you you're not within your right to do so. 😉
