Reply 16740 of 27549, by imi
- l33t
Thermalwrong wrote on 2020-09-24, 21:38:Making a PC/104 to ISA riser, it might work, it's cheaper than buying an old stock one and this one has an ATX power connector 😁 Much easier than trying to solder one up. Honestly whoever made the PC/104 16-bit connector, I dislike them, it's so bad to route to a 16-bit ISA slot.
nice, but... umm, why didn't you just route them straight out? the PC104 pinout follows exactly the same order as ISA, you did for some pins but then start to mix and match? ^^
I can't quite follow some traces on that image.
...but I should probably try that sometime myself before x3
