First post, by poseidon
Hey all,
I am trying to use a feature called "chartran" in Dark Sun Wake of the Ravager. Basically it reads from a file in one game to use in another. I have both games inside C:\DOSGAMES, each in their own folder, and when I try to use the chartran feature, it can read the file but it says
"unable to alloc -12648449 memory for the item data". can't find help anywhere else about this.
I assume I just have something set up wrong, so I went into the config file and increased the memsize to 63. still the same issue.
if anyone can shed any light on what i'm doing wrong, i would greatly appreciate it.
Reply 3 of 3, by poseidon
Thank you.
LOADFIX fixed the memory issue, because now it is just telling me it can't properly load instead of saying it's a memory problem. Likely, that was the issue the whole time. I will mess around with my folder locations and see if I can't get it to be able to find the files.
