First post, by enaiel
- Member
I'm looking to downgrade my P3 Retro Dos PC into one that will play a more broader variety of DOS games (from 1989 to 1997). This will continue to be a pure DOS PC (no Windows allowed!).
I basically have 3 requirements for this downgrade:
- Compatibility, as mentioned above.
- Must fit in the same MicroATX case as the above PC.
- Use the cheapest parts to achieve the above 2 requirements.
Regarding motherboards, from skimming through the forums, the recommended approaches seems to be either a Slot 1 440BX, or a Super Socket 7 K6+. They are both hard to find in MicroATX format. So which of the two are more compatible, and which would be cheaper? Any ballpark figures?
Any alternative approaches that meet my requirements?
Thanks!
