First post, by SuperBeastie
Hello having a problem with: Award Winners Gold (collection of four games). For two of the games in does not need the "key disk" to run, so they work fine. But for two of them (Elite Plus and Zool) it wants the disk.
Now I HAVE the original disk, and copied it to "~/disks/awd1" .
So when dos box ran I mounted that as a floppy like so:
"mount a "/home/daniel/disks/awd1" -floppy
and also mounted by game directory.
So the program menu came up, if I try to play Elite or Zool. It still asks me to insert the key disk, what am I doing wrong? (if anything).
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
they might need lowlevel support
in that case you need an image if your disk and mount it with imgmount
Water flows down the stream
Reply 2 of 3, by SuperBeastie
OK, I made an image of the disk, and then did imgmount like so:
imgmount a "/home/daniel/floppyimage/aw.img" -t floppy
But I still get the same problem, when trying to run the game.
Reply 3 of 3, by eL_PuSHeR
If the disk protection use low level disk routines (even undocumented ones), you may be out of luck unless you get a crack. That's illegal so don't think about asking for one here.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
