Mounting iso images
First post, by macuser
I put the .iso file in a folder called DAGGF in my dosbox directory ad typed
imgmount D "C:\DAGGF\DAGGF1.iso" -t iso
and hit enter and got "Image file not found"
what should i do??? im using a mac. Do i have to mount the .iso on my desktop first???
Reply 2 of 4, by macuser
wait what???
could you write out a command line for me
Reply 3 of 4, by DosFreak
Well I guess if you successfully mounted your host filesystem in DosBox so that you have a "C:" drive in DosBox then you may be able to specify the "C:" drive to mount your .ISO.
Don't know about OSX but on Linux I do a "IMGMOUNT C /home/username/dosbox/image.iso -t iso"
Make your games work offline
Reply 4 of 4, by prompt
Both should work (dosbox drive and host drive).
You can try as well (in dosbox) to change into the directory containing the iso and mount it from there without any path elements: e.g. imgmount d myiso.iso -t iso
In case you are using dosbox 0.63 on a ppc mac: There was bug that caused this (wrong) error message. The 0.65 version should fix that.
