First post, by Bancho
- Oldbie
Hi All,
I recently managed to get a Supermicro PIIIDR3 V1.1 i840 Motherboard and would like this to be my next project. The board works fine (tested with 2 500mhz P3's). Some of the caps are bulging so these will be replaced. My question is around using S370 cpu's in Slokets. I have a pair of nice 850mhz (SL4Z2) CPU's I would like to use at potentially 133mhz fsb. I have a pair of standard Slokets but as is to be expected, I tried them in the board and it will not post. Does anyone know if there are any recommended Slokets which will give me the opportunity to run the 850's?
When it comes to Dual P3's I'm pretty much a noob, but i can see a potential awesome system around this board.
Please chime in with any thoughts and advice. Cheers!
