Reply 36381 of 52813, by devius
appiah4 wrote on 2020-10-09, 07:47:
Use a very sharp razor or a thin x-acto knife to separate the legs, and do not be anal about bending them to proper shape, just separate them.
And do it very slowly.
Reply 36382 of 52813, by lolo799
SodaSuccubus wrote on 2020-10-08, 16:31:
Let's get some Japanese retro computing up in here'! […]
Won a very nice condition PC9821-CE2 on YA, for a decent price. Certainly cheap enough to makeup for the crippling shipping fees.
I didn't *need* it but a tiny part of me allways wanted to own atleast one Japanese home computer and since these are somewhat close to our old MS-DOS machines here, I thought what better machine?
A bit of variety is always nice!
What are its specs?
I just received a NEC G8WMP card and I don't even own a PC98xx to put it into...
194.2 KiB
44.95 KiB
I bought two POST cards recently, a PCI one and a PCI/ISA one, I'll make a thread about the latter cause it really fucked up my Asus P55T2P4 motherboard...
64.48 KiB
Reply 36383 of 52813, by cyclone3d
lolo799 wrote on 2020-10-09, 16:19:
A bit of variety is always nice! What are its specs? […]
What are its specs?
1. What exactly does that NEC card do? Looks like it has an input and an output.
2. Did you install the PCI/ISA POST card the wrong way in an ISA slot?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 36384 of 52813, by lolo799
cyclone3d wrote on 2020-10-09, 16:35:
1. I have no idea, indeed it does look like an input, or a passthrough perhaps...
2. nope it was correctly oriented, wait for the thread.
Reply 36385 of 52813, by darry
What are its specs?
This NEC card is similar to this https://vgamuseum.ru/gpu/matrox/nec-g8ydq-mat … d-nec-d95177gn/ except for the VGA chip used .
Reply 36386 of 52813, by HanJammer
devius wrote on 2020-10-09, 15:23:
Those cards with the black connector. Are they twin CGA cards in SLI? 😆
3270 PC had a special 1, 2 or 3 piece graphic adapter which was a CGA/MDA combo but not 100% compatible with either.
Reply 36387 of 52813, by Hanamichi
lolo799 wrote on 2020-10-09, 16:42:
Believe in a 9821 system it only functions as a Windows accelerator and needs the motherboard video output for DOS.
Reply 36388 of 52813, by Munx
Khorne wrote on 2020-10-09, 10:27:
Thanks for the tip, any idea what to look for if I need to get another PSU ? 20A on 5v with modern PSUs seems quite rare (750W+ […]
Munx wrote on 2020-10-08, 17:54:
Welcome! That's a great haul you got there! […]
Khorne wrote on 2020-10-08, 10:45:
So when I sum all the costs, I got all this for around 70-75 USD, and if I can make a single working PC from all this it could be a nice non-3d gaming rig 😀
Welcome!
Just one little thing - FSP power supplies from that era tend to have really bad caps, so don't be surprised if you start having stability issues. Finding replacements isn't hard though, socket 7 isn't power hungry.
Thanks for the tip, any idea what to look for if I need to get another PSU ? 20A on 5v with modern PSUs seems quite rare (750W+ high end units and similar have it), so how low can I go ?
Or even better, if anyone recently put up together a s7 build with a brand new PSU from the shop, don't hesitate to let me know what you are using.
My main concern is to minimize the chance of PSU taking everything with it if it dies 😉
FSP400-GHN is my go-to retro PSU. 23A on the 5V rail, 5V load does not impact the 12V rail, good price and 80+ bronze. From what I've seen on Youtube Corsair PSUs seem to handle retro builds pretty well too, even the lower-end ones.
My builds!
The Underdog - The budget K6
Reply 36389 of 52813, by imi
got this little hunk of plastic today :3
it had been modded on the left side so there's a hole there, but that's way easier to fix than the other case I found for a reasonable price, that had the whole floppy section cut out ^^
148.62 KiB
123.38 KiB
Reply 36390 of 52813, by brostenen
Today I bought a set, of nearly every Commodore64 chips, for my SixtyClone project. Well. The ones I was missing.
I had the PLA, SID, CIA's and VIC-II bought some time ago. Now I only need to source kernal-rom, character-rom, basic-rom and the memory.
The plan is to buy modern replacements as much as I can. That means S-Ram and not D-Ram, eliminating the VSP-Bug.
Even the RF modulator is a modern replacement solution, that do not have RF-Out, yet will make S-Video and Composit working.
I will have to figure out if I will go with some modern solution like JiffyDos or something or I will go old school original.
The end result will be a nice black motherboard in a nice black case. (SixtyClone-Black-250466-systemboard and Pixelwizzard Black-Case).
Still not sure what I will name the finished machine. Hmmm.... Shall be something nice.
Reply 36391 of 52813, by Aublak
HanJammer wrote on 2020-10-09, 11:57:
This IBM 3270 PC (aka IBM 5271). Condition is not perfect, but it's pretty much complete - missing a PC speaker, some screws and ribbon cables... although it will make a good repair/restoration video for a youtube channel I'm thinking about...
Wow, what a great catch. Yeah, I'd love to see a breakdown video of it. These XT machines are really fascinating.
Reply 36392 of 52813, by Buttcake
Bought a semi-surprise package today in the form of a yellowed Targa case containing an Asus A8N-SLI Premium, Radeon X850 *something* and an Athlon64 3500+ (Venice)
No pictures of the inside at all were given, so I have no idea how good (or bad) the caps'n'stuff are gonna look. Luckily, regarding the 1.50€ + postage price tag, the risk is manageable. 😁
"One does not simply *not* have enough computer stuff." - Gandhi
Reply 36393 of 52813, by Wolfus
Poor little fella... Dirty as hell but working with german system 6 installed and ram expanded to 4MB.
Reply 36394 of 52813, by Munx
Todays 10Euro haul:
448.51 KiB
32MB (Im guessing) Edo memory;
Matrox Millenium2, 2MB;
Cirrus Logic GD5480, 4MB 100MHz sgram;
Voodoo 4MB with heatsinks...
...Aaand a Radeon HD5570, because Im building a PC for my grandma to browse the web and it needs video outputs.
My builds!
Reply 36395 of 52813, by hejluxom
Bought something, but no clue what. 😁 will need some detective work. It's quite big though, and judging from the battery compartment, it should be able to do stand alone work.
Guessing collecting some data. Looks like there is a parallel port connection on the top and infra red.
It's like a 10 usd lottery ticket. 😁
    1.64 MiB
    1.92 MiB
    1.95 MiB
Reply 36396 of 52813, by PTherapist
imi wrote on 2020-10-09, 18:25:
got this little hunk of plastic today :3 it had been modded on the left side so there's a hole there, but that's way easier to f […]
That looks in pretty good condition, nice find!
Reply 36397 of 52813, by CrFr
hejluxom wrote on 2020-10-10, 17:42:
I think it is swedish, judging from the letters Å, Ä and Ö in the keypad. Company name printed in the PCB seems swedish too (AB=aktiebolag). Maybe it is some kind of programming console for industrial machinery? Interesting piece.
Reply 36398 of 52813, by Vegge
Todays highscore (heh)
Got this for free. 😀
558.52 KiB
545.98 KiB
