Reply 16881 of 30428, by RetroLizard
What's the best, or most reliable, brand for 486 PSUs? Looking around for potential parts, and not sure which one to go with.
Or should I go with a modern one, and a converter cable? If so, which one?
Reply 16882 of 30428, by xcomcmdr
That's a very cool Windows 3.11. Damn !
Reply 16883 of 30428, by Cloudschatze
Deksor wrote on 2020-10-08, 06:18:
How do you cycle through the wallpapers ?
There are undoubtedly more elegant ways of doing this, but it works, and completes in a fraction of a second:
WIN.BAT
@ECHO OFF
CD C:\WINDOWS
WIN.COM
Where the WIN.INI file specifies the wallpaper name of "1.BMP" (with a 15-pixel X-axis offset from 0, concerning the position).
xcomcmdr wrote on 2020-10-08, 06:37:
I wish! This system is (within reason) incapable of running Windows 3.11; I'm limited to 30-year-old Windows 3.0 running in real-mode.
Reply 16884 of 30428, by PTherapist
Been battling another Socket 370 PC with a VIA chipset, running Windows 2000. Had stability issues in games which I fixed with some BIOS tweaking and latency issues which I've yet to resolve but have an idea about. Also the irritating HDD stuck in PIO mode issue which requires the removal of the IDE controller and reboot to fix. Simply ticking the DMA box on/off and rebooting each time isn't enough.
I really really hate VIA!
Reply 16885 of 30428, by appiah4
PTherapist wrote on 2020-10-08, 10:16:
Have a similar issue with PLE133T, it hard locks up at boot with most OSes (modernish linux, Win2K, etc.) and exhibits the same behaviour with Win9x after Via 4in1 installed when CF-IDE adapter is set to UDMA; it only works when that IDE device is set to PIO mode. It works fine with my main 80GB HDD (set to 32GB via jumpers, unfortunately) though.
Reply 16886 of 30428, by Deksor
Cloudschatze wrote on 2020-10-08, 08:09:
There are undoubtedly more elegant ways of doing this, but it works, and completes in a fraction of a second: […]
WIN.BAT
@ECHO OFF
CD C:\WINDOWS
WIN.COM
Wow that's quite clever actually ^^
I had thought of this before but instead I was thinking of making a C program that would randomly pick images from a given directory and pick one randomly at boot
Reply 16887 of 30428, by brostenen
In the process of setting up shelfes for my vintage stuff. Not done yet....
The attachment IMG_20201008_145437356.jpg is no longer available
Reply 16888 of 30428, by PTherapist
appiah4 wrote on 2020-10-08, 10:45:
This is a PLE133 chipset too, not sure which variant. Thankfully I haven't had any lockups with DMA enabled, it just seems to want to go back to PIO whenever it feels like it. It may be the onboard IDE doesn't completely like the SATA-IDE adapters I've been using, though I have had it running successfully with 2000 displaying Ultra DMA Mode.
Reply 16889 of 30428, by dionb
Received mail from Belgium, which means Serdaco stuff 😀
The Chill MIDI interface is back in stock, so snapped one up. After half an hour soldering, I had this:
The attachment IMG_20201009_200537.jpg is no longer available
Time to externalise my Trust Korg Super Sound module and hook it up to my Roland A-880 😀
Of course I underestimated the size of the board so will have to hack the case for the Chill, but that kind of thing keeps life interesting.
Reply 16890 of 30428, by Thermalwrong
PTherapist wrote on 2020-10-08, 14:01:
Hmm, I guess I dodged a bullet setting up the cheapy tualatin PLE133T board with a hard drive. I'll have to try it out with a UDMA CF card at some point.
A couple of weeks back I got this untested VLB Cirrus Logic card and finally made time for it today since I've got my big VLB 486 up on the bench.
It didn't work, no video display. 🙁
Then I looked closer, one of the blue capacitors might actually be a tantalum, and it looks crushed. When I removed that it actually looked burned. I put a cheapy electrolytic in its place but it still didn't boot 😒
The attachment cl-gd5428-repaired.jpg is no longer available
But wait, why doesn't this one have a clock crystal? My big VLB 486 has a taller CL-GD5428 card in it so I compared them and looked at some pictures online. They all have the 14.318mhz clock crystal, I guess that datasheet was pretty specific since the designs of other similar cards are all the same.
I borrowed the crystal from my working card and it's working!
Another 14.318mhz crystal (well, 30 of them) is on its way from China 😀
I've also got to start making some progress on a 3d printable AT case again, I've got too many computers with no suitable case. I've got lots of components measured up ready to fit together, I just need to figure out how it would all fit together and make it printable on my i3
Reply 16891 of 30428, by Turbo ->
Copying all the files from 81Mb Caviar 280, which was installed in a 286 PC to 1GB SD card. I call this preserving digital history.
Reply 16892 of 30428, by PTherapist
Decided to begin my planned 2003 gaming builds. Dug out the first candidate PC, already built and left how it was since the PC was last used about 10 years ago, minus a few "borrowed" parts. Opened it up and immediately spotted 4 bulging & leaking capacitors. Another board for the "to-do" recapping pile, bloody Gigabyte! Board was a Gigabyte GA-7N400 L, Socket A, nForce2 Ultra 400 chipset with Athlon XP 3200+.
Luckily I had a spare motherboard that looks fine and should suffice (except for having only 3 ram slots vs the 4 on the Gigabyte board) - MSI K7N2, same chipset and same CPU (I had 2 of them in my collection).
Reply 16893 of 30428, by wiretap
Making a backup of my Amiga 2000 SCSI hard drive using my dual Pentium III machine. Just installed an Adaptec AHA-2930CU and a SCSI hot swap bay. Using Winimage 8.1 on Windows XP.
My Github
Circuit Board Repair Manuals
Reply 16894 of 30428, by kdr
Picked up two of these nice ASUS Socket 7 boards this weekend, both with AMD K6-200Mhz CPUs, one with 64MB (pictured) and the other with 128MB:
The attachment IIMG_20201011_163831_1.jpg is no longer available
This board has two power connectors, one AT and one ATX! So I won't have to consume a valuable AT PSU if I build a system with this board. (And it has three ISA slots, which is very generous when compared to my current Super Socket 7 board's one lone ISA slot, which is just pathetic.)
Includes onboard VGA, which is fine by me since I'm mainly interested in using this one for Pentium-era DOS gaming.
After removal of the tonnes of accumulated dust, cleaning out the heatsink, and applying new thermal paste it is time to boot memtest86:
The attachment IIMG_20201011_163820.jpg is no longer available
Strangely, this board is unable to boot from my bootable memtest86 CD-R. The BIOS claims to support booting from CD, hmm. I've tried numerous CD-ROM drives that are known to work fine in other systems, but no go. So far that's the only issue -- what a haul!
Reply 16895 of 30428, by Horun
kdr wrote on 2020-10-11, 03:51:
Nice set of mobo's.
I never run Memtest on cd or usb thumb drive on anything older than soc775... too many quirks. Some versions of Memtest are very hardware specific (ver 4.0 will run on 486 but v4.3 will not). You should use a 1.4Mb 3.5" floppy disk and use the appropriate version for the older hardware you are testing. It is a Pentium board, cannot expect it to work like some soc 115x board 😀
Reply 16896 of 30428, by kdr
Horun wrote on 2020-10-11, 04:40:
Yep, this is what I'm slowly learning through trial & error: it's always better to find a version of the software that is roughly the same vintage as the hardware...
Reply 16897 of 30428, by Horun
kdr wrote on 2020-10-11, 04:47:
I use Memtest v4.3.7 on floppy for a lot of Pentium/Pentium 2 era boards. If you cannot find it let me know.
Reply 16898 of 30428, by Disruptor
This forum already shared the trial and error conclusions:
Try memtest86+ 4.10
memtest86 that works for 486
Reply 16899 of 30428, by kolderman
Wasted hours destroying a win98 build by trying many different drivers to get a SB Live! working.
Realized I had the wrong audio device selected as preferred in Multimedia 😒
