Munt Reloaded - Development
Reply 960 of 965, by clearcase
That's interesting, thanks. I have MT-32 ROMs here, would be interested to know which ROMs have the lookup tables and their address and size if it's convenient. An idea of how to make use of them would be great too. I can code fairly well in C but maths is not a strong point at all.
Reply 962 of 965, by clearcase
Okay, thanks. I wanted to try and get a bit accurate conversion if possible but this is not the thread for that really. Should I start a thread about that or is it not really the right forum? I'm new here. Thanks again.
Reply 963 of 965, by sergm
Of course, feel free to start a new thread for it. But I don't insist because I'm not a moderator, yet this thread turned to a mess long time ago 😀
I'd just note that LA32 doesn't perform the conversion of the PCM ROM data to linear wave like you probably expect . Instead, it handles samples in the log space first (for both speed and accuracy), and does just some final steps in the linear space. Albeit, it is a general note, and for PCM samples this is rather contrary, but still the integer (or fixed point?) exponent is applied to PCM data that has already been processed.
Reply 964 of 965, by KainXVIII
Scummvm dev build already includes Munt 2.4.1, but stand-alone Munt users (like i am) still stuck with 2.3.0 version 😥
Reply 965 of 965, by Roland User
If sent sysex from this file - all parts will be off
