First post, by Nexxen
Bios string:
D286-6069-043009-K8
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 1 of 6, by Nexxen
For later use and bios dump for Mr. Deksor
Bios has two roms, odd and even.
    ATROM286.zip
    39.98 KiB
    30 downloads
Reply 2 of 6, by Nexxen
When I plug my graphics card before the controller card, image is always good.
If I plug it after the image can be corrupt like showing in different colors (usually green and dark blue) or nothing at all.
Is there something wrong?
Reply 3 of 6, by Deksor
Thank you 😀
This is actually quite an oddity, I can't find any infos about this board ...
It doesn't even have a real name 🙁
However, I think I found a manual 😁
http://www.win3x.org/uh19/motherboard/show/5231
It's not a 100% perfect match for the RAM area, but it was probably designed for an earlier revision or something (MTL did something wrong)
Reply 4 of 6, by mkarcher
Nexxen wrote on 2020-10-14, 16:06:
Sounds like a contact problem in the slot the graphics card doesn't work in. ISA slots may acquire some corrosion over time. Oftentimes it helps to re-insert the card some times to scratch the corrosion away (just like re-inserting gameboy cartridges helps). Broken traces on the mainboard might be a culprit too, but that's less common. PCs don't need normal ISA cards in specific slots (except for the odd "slot 8" of the IBM XT), so either order of the cards is supposed to work.
Nevertheless, also double check your monitor cable. Maybe it has broken wires and it depends on the position of the VGA connector at the computer whether they still make good contact.
Reply 5 of 6, by Nexxen
mkarcher wrote on 2020-10-14, 21:29:
I thought about oxidised contacts.
The board needs a good cleaning session and some contacts cleaner. Not like that's a problem or maybe it's the video card itself.
Not that I'm getting a refund from the store 🤣
@ Deksor: bios image uploaded, see above
Reply 6 of 6, by Nexxen
EVEN and ODD chips
Taiwan Microchip
27c256-15/J 8952cdd prgm@12.5V
Brand is "Microchip" logo an M that looks like a double peek mountain. (Microchip memory on TL866)
