Reply 1140 of 1231, by PoulpSquad
- Member
Qbix wrote on 2020-10-01, 19:54:can you attach a configfile with that problem ? As I can't reproduce it at my place. (using the non-ECE code)
Hello Qbix,
I think I found something new about this issue.
If I set the speed in the config file and run a game "manually" from the command line everything is fine.
If I set the speed in the config file and run the game through a batch file, it fails.
Please find my current config file and the batch in question.
Edit:
Could it be that the % symbol gets somehow eaten up? Maybe DOSBox considers it part of a variable and it doesn't get parsed the way I intended it to be?
Edit 2:
Yup, that was it. Using cycles=auto 5000 90%% instead of cycles=auto 5000 90% did the trick.
Thanks for reading this and sorry for the clutter!
