First post, by keenerb
Can't find a lot of info on this rom, and it's not in my minipro chip supported list.
Any suggestions as to what I can use to read this chip? It's the ROM of a fairly rare system it seems, I'd like to archive it for posterity.
keenerb wrote on 2020-10-18, 19:16:Can't find a lot of info on this rom, and it's not in my minipro chip supported list.
It is a Samsung 128KX8, CMOS, DIP32 and the datasheet is out there but does not give much info as to what it compatible with or comparable to 🙁
Do you have a PCI NIC with a 32pin rom socket ? If so you could try NSSI or other software ROM reading utility.....
Horun wrote on 2020-10-18, 21:07:keenerb wrote on 2020-10-18, 19:16:Can't find a lot of info on this rom, and it's not in my minipro chip supported list.
The datasheet quite clearly says "JEDEC standard", which means this chip is compatible with nearly any other 128K x 8 DIP32 EPROM, EEPROM or Flash ROM, like e.g. the Winbond 29ee011 Flash ROM or the ST 27C1001 EPROM. I guess that winbond chip is supported by the minipro. If you can convince the minipro to read the chip like a 29ee011 even if it does not respond to an ID command, you have the dump.
Thanks, I was able to dump it as a 27C010 chip once I figured out how to disable chip id checking.
Hi there, what kind of this rare system?
Cheers,
Great Northern aka Canada.
Oh sorry, it's an Emerson 4412EC. A 286-12mhz with some nice built-in features.
Could you post a copy of the image file here, for anyone else who may need it?
debs3759 wrote on 2020-10-18, 22:48:Could you post a copy of the image file here, for anyone else who may need it?
I posted it in the Vogons Driver library thread.
Cool, thanks
