First post, by C0deHunter
Hello all,
I am building a "retro" P4 Windows XP system, and I wanted to see if there is a list of Windows XP specific games out there.
I know Quake IV is such game, but I need to expand on that one.
Thanks!
PIII-800E | Abit BH-6 | GeForce FX 5200 | 64MB SD-RAM PC100 | AWE64 Gold | Sound Canvas 55 MKII | SoftMPU | 16GBGB Transcend CF as C:\ and 64GB Transcend CF D:\ (Games) | OS: MS-DOS 7.1-Win98SE-WinME-Win2K Pro (multi-OS menu Using System Commander 2K)
Reply 1 of 12, by IlhanK
With "Windows XP specific" are you suggesting games that only run on Windows XP?
Because Quake 4 runs just fine on my Win 10 machine.
Reply 2 of 12, by C0deHunter
Yes, exactly, that's what I meant 😁
Reply 3 of 12, by kolderman
I'd say almost all have issues to various extents. Try and find a winXP game on steam or gog where people aren't complaining it doesn't work on win10. In addition you will have wide-screen issues on most titles so a dedicated winXP box with a 19" lcd is the way to go.
Reply 4 of 12, by leileilol
For some really XP exclusive games, there's those on the XP Plus pack (even if they have other versions that can technically run on Win98)
Debian's fucked
Reply 5 of 12, by nd22
I know quite a few games that have problems running on later OS but run just fine on XP with all the bells and whistles! Some of them predate XP but still run just fine on it. IMHO Windows XP is the most compatible out of all Windows version with all the games I tested. To name a few:
1. Far cry 1 - correct reflections and water simulation only on XP
2. Quake 4 - correct textures only on XP
3. Panzer General 2 - runs fine on 98/ME/2000/XP but simply refuses to start on 10.
4. Diablo 1 hellfire - fully XP compatible but no luck on 10
5. Dark reign 1 - no problem on XP
Just to be clear: modding/deleting/adding something to a particular game to make it run on 10 without all the original content does NOT make it problem free!
Reply 7 of 12, by C0deHunter
Thanks, that’s exactly what I meant:
Not XP specific per se, but *XP period specific*:
When I installed Quake 4, the read me states the *minimum* specification as P4, Windows XP, etc.
That is the kind of game that I I’m looking for.
But these lists are great, thank you!
Reply 8 of 12, by Jorpho
nd22 wrote on 2020-10-20, 07:43:
I know quite a few games that have problems running on later OS but run just fine on XP with all the bells and whistles! Some of […]
I expect most of those problems are much more likely to be related to drivers rather than changes to the OS. But then, if the correct drivers are only available for XP, it doesn't make much of a difference whether it is an OS problem or not.
Reply 9 of 12, by C0deHunter
According to Phil’s Computer Lab, anything after 2006, would be better suited on Vista, as they would tend to use DX 10.
Reply 10 of 12, by Jorpho
C0deHunter wrote on 2020-10-20, 16:00:
Seems to me that I'm still regularly seeing games on Steam that use DX9.
Reply 11 of 12, by C0deHunter
XP was released on 2001, so any game list from 2002 to 2007ish?
Reply 12 of 12, by kolderman
C0deHunter wrote on 2020-10-20, 17:18:
The later the game, the more likely it is to run. I would say the XP games that were still likely compatible with Win98, probably from 2002-2005, are most likely to to have issues. But even some Windows vista games will still have issue on Win10, it really depends.
