First post, by boonebluewolf07
I've read the faq, the readme file, and asked around, and I just can't figure out how to start up TIE Fighter. I've got the first version of the game, on floppy disk. Every DOS emulator I use gives me the same message. I don't have enough EMS to have voices or music, and the game doesn't start.
I'm using the latest version of DOSBOX, have put the game into compatibility for win 95, and the sound tests for the game were successful. Any help would be appreciated.
Reply 1 of 19, by wd
Rank DOSBox Author
DOSBox Author
Please post the EXACT error message, and info about your system,
how you configured dosbox (mounting, version etc.) and what you
already tried.
TieFighter works fine for me with default settings.
Reply 2 of 19, by boonebluewolf07
Here is the exact message.
Using 2000k of EMS will add more music and speech. 572K MAIN, 896k EMS required!
I've tried setting EMS=false in the config along with XMS, that hasn't worked. Tried more cycles, fiddled with the properties setting on the TIE.exe, like making it run in compatibility with 95, or changing the EMS on the memory tab.
Here is my config.sys
[sdl]
# fullscreen -- Start dosbox directly in fullscreen.
# fulldouble -- Use double buffering in fullscreen.
# fullresolution -- What resolution to use for fullscreen: original or fixed size (e.g. 1024x768).
# windowresolution -- Scale the window to this size IF the output device supports hardware scaling.
# output -- What to use for output: surface,overlay,opengl,openglnb,ddraw.
# autolock -- Mouse will automatically lock, if you click on the screen.
# sensitiviy -- Mouse sensitivity.
# waitonerror -- Wait before closing the console if dosbox has an error.
# priority -- Priority levels for dosbox: lowest,lower,normal,higher,highest.
# Second entry behind the comma is for when dosbox is not focused/minimized.
# mapperfile -- File used to load/save the key/event mappings from.
# usescancodes -- Avoid usage of symkeys, might not work on all operating systems.
fullscreen=false
fulldouble=false
fullresolution=original
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
usescancodes=true
[dosbox]
# language -- Select another language file.
# memsize -- Amount of memory dosbox has in megabytes.
# machine -- The type of machine tries to emulate:hercules,cga,tandy,pcjr,vga.
# captures -- Directory where things like wave,midi,screenshot get captured.
language=
machine=vga
captures=capture
memsize=16
[render]
# frameskip -- How many frames dosbox skips before drawing one.
# aspect -- Do aspect correction, if your output method doesn't support scaling this can slow things down!.
# scaler -- Scaler used to enlarge/enhance low resolution modes.
# Supported are none,normal2x,normal3x,advmame2x,advmame3x,advinterp2x,advinterp3x,tv2x,tv3x,rgb2x,rgb3x,scan2x,scan3x.
frameskip=0
aspect=false
scaler=normal2x
[cpu]
# core -- CPU Core used in emulation: simple,normal,full,dynamic.
# cycles -- Amount of instructions dosbox tries to emulate each millisecond.
# Setting this higher than your machine can handle is bad!
# You can also let DOSBox guess the correct value by setting it to auto.
# Please note that this guessing feature is still experimental.
# cycleup -- Amount of cycles to increase/decrease with keycombo.
# cycledown Setting it lower than 100 will be a percentage.
core=normal
cycles=3000
cycleup=500
cycledown=20
[mixer]
# nosound -- Enable silent mode, sound is still emulated though.
# rate -- Mixer sample rate, setting any devices higher than this will
# probably lower their sound quality.
# blocksize -- Mixer block size, larger blocks might help sound stuttering
# but sound will also be more lagged.
# prebuffer -- How many milliseconds of data to keep on top of the blocksize.
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
# mpu401 -- Type of MPU-401 to emulate: none, uart or intelligent.
# device -- Device that will receive the MIDI data from MPU-401.
# This can be default,alsa,oss,win32,coreaudio,none.
# config -- Special configuration options for the device. In Windows put
# the id of the device you want to use. See README for details.
mpu401=intelligent
device=default
config=
[sblaster]
# sbtype -- Type of sblaster to emulate:none,sb1,sb2,sbpro1,sbpro2,sb16.
# sbbase,irq,dma,hdma -- The IO/IRQ/DMA/High DMA address of the soundblaster.
# mixer -- Allow the soundblaster mixer to modify the dosbox mixer.
# oplmode -- Type of OPL emulation: auto,cms,opl2,dualopl2,opl3.
# On auto the mode is determined by sblaster type.
# All OPL modes are 'Adlib', except for CMS.
# oplrate -- Sample rate of OPL music emulation.
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
[gus]
# gus -- Enable the Gravis Ultrasound emulation.
# gusbase,irq1,irq2,dma1,dma2 -- The IO/IRQ/DMA addresses of the
# Gravis Ultrasound. (Same IRQ's and DMA's are OK.)
# gusrate -- Sample rate of Ultrasound emulation.
# ultradir -- Path to Ultrasound directory. In this directory
# there should be a MIDI directory that contains
# the patch files for GUS playback. Patch sets used
# with Timidity should work fine.
gus=true
gusrate=22050
gusbase=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND
[speaker]
# pcspeaker -- Enable PC-Speaker emulation.
# pcrate -- Sample rate of the PC-Speaker sound generation.
# tandy -- Enable Tandy Sound System emulation (off,on,auto).
# For auto Tandysound emulation is present only if machine is set to tandy.
# tandyrate -- Sample rate of the Tandy 3-Voice generation.
# disney -- Enable Disney Sound Source emulation.
pcspeaker=true
pcrate=22050
tandy=auto
tandyrate=22050
disney=true
[bios]
# joysticktype -- Type of joystick to emulate: none, 2axis, 4axis,
# fcs (Thrustmaster) ,ch (CH Flightstick).
# none disables joystick emulation.
# 2axis is the default and supports two joysticks.
joysticktype=2axis
[serial]
# serial1-4 -- set type of device connected to com port.
# Can be disabled, dummy, modem, directserial.
# Additional parameters must be in the same line in the form of
# parameter:value. Parameters for all types are irq, startbps, bytesize,
# stopbits, parity (all optional).
# for directserial: realport (required).
# for modem: listenport (optional).
# Example: serial1=modem listenport:5000
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
# xms -- Enable XMS support.
# ems -- Enable EMS support.
# umb -- Enable UMB support (false,true,max).
xms=false
ems=false
umb=true
[ipx]
# ipx -- Enable ipx over UDP/IP emulation.
ipx=false
[autoexec]
# Lines in this section will be run at startup.
Reply 3 of 19, by wd
Rank DOSBox Author
DOSBox Author
Expanded memory means the game wants ems=true, the xms/umb
switches shouldn't matter (but you can try to set them to false as long
as ems remains true).
Do you get different results with ems=true and xms=false?
Reply 4 of 19, by boonebluewolf07
Thank you oh so very much. I now have a life debt unto you. Well, not literally, but thank you a bunch for getting this to work.
Reply 5 of 19, by boonebluewolf07
One last question, just to make sure.
Will TIE Fighter automatically detect a joystick? I don't have one as of yet, just asking before I get one.
Reply 6 of 19, by wd
Rank DOSBox Author
DOSBox Author
Hm i think there was a calibration screen inside tiefighter.
So if you got the joystick working in windows, it should be detected
by sdl (thus dosbox) as well.
Reply 7 of 19, by haibane
I have a similiar problem with TIE Fighter (it's the first disquette version too). No matter what I try it just doesn't want to run. Here's what the game says:
set FILES=30 in your config.sys
Reply 8 of 19, by haibane
Actually nervermind. I managed to make the game work. I somehow messed the subdirectories while copying the game folder.
damn I'm so n00bish 🙁
Reply 9 of 19, by Aequitas
ok. i have the exact same problem. as in the error message is the same.
now, i am a retard when it comes to this kind of stuff and i will admit that.
I guess i really need someone to walk me through this config thing. as in how the get there and everything. i have been trying for the past 2 hours.
I am running XP service pack 1 if that helps.
I also downloaded DOSbox and i have no idea how to work it right. I thought i mounted the directory but it keeps telling me it can't load it.
any help you guys can offer will be appriciated cause this is my most favorite game. 🙁
THanks
Reply 10 of 19, by MiniMax
Rank Moderator
Moderator
Start here: 60 seconds guide to getting your game to run in DOSBox
_________________
Reply 11 of 19, by Aequitas
thanks man. turns out i was mounting the drive incorrectly.
the game runs great.
kudos to yall
Reply 12 of 19, by Slipher
same problem with TIE (Floppy Version)
i have the same errror message: using 2000k of EMS will add more music and speech. set FILES=30 in your config.sys
i have activated and deactivated EMS and XMS and added FILES=30 in autoexec.
its mounted correct and i have no idea waht to do.....
can anyone help me?
Reply 13 of 19, by MiniMax
Rank Moderator
Moderator
wd wrote:
Please post the EXACT error message, and info about your system, how you configured dosbox (mounting, version etc.) and what you […]
already tried.
_________________
Reply 14 of 19, by Slipher
my config file:
[sdl]
fullscreen=false
fulldouble=false
output=surface
autolock=true
sensitivity=100
waitonerror=true
usescancodes=true
[dosbox]
language=e:\Programme\DOSBox-0.65\deutsch.lng
machine=vga
captures=capture
memsize=16
[render]
frameskip=0
aspect=false
scaler=normal2x
[cpu]
core=normal
cycles=3000
cycleup=500
cycledown=20
[mixer]
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
mpu401=intelligent
device=default
config=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
[gus]
gus=true
gusrate=22050
gusbase=240
irq1=5
irq2=5
dma1=3
dma2=3
[speaker]
pcspeaker=true
pcrate=22050
tandy=auto
tandyrate=22050
disney=true
[bios]
joysticktype=2axis
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
xms=false
ems=true
umb=false
[ipx]
ipx=false
[autoexec]
set files=40
mount C C:\Spiele\Tie
c:\keyb gr
c:
THE ERROR MESSAGE is:
"Using 2000K of EMS will add more music and speech.
set FILES=30 in your config.sys"
I tried to set these FILES=40 and it seems it had worked , if i type "set" it shows FILES=40
And have activated / deactivated EMS and XMS... but no succes..
Reply 15 of 19, by wd
Rank DOSBox Author
DOSBox Author
What dosbox version is that?
Please remove the keyb statement and see if it works then.
Reply 16 of 19, by Slipher
version is 0.65
and it didnt do anything when i removed the keyboard driver....
Reply 17 of 19, by wd
Rank DOSBox Author
DOSBox Author
Try to use "mount C C:\Spiele" and see if the game works then, if it
doesn't mount the installation directory at d: and re-install the game.
Reply 18 of 19, by Slipher
no effect at all .. only have my old installed version, because my pc has no floppy drive ...
Reply 19 of 19, by wd
Rank DOSBox Author
DOSBox Author
Well maybe there's some config file, reading the posts above it might
be picky about the installation path.
