First post, by vetz
So I've been looking into buying a proper openair testbench. Do anyone know if any model will fit AT motherboards as well as ATX?
Reply 1 of 7, by Doornkaat
You won't accept 'pizzabox' as an answer I assume? 😉
Reply 3 of 7, by imi
so you probably won't accept metal monitor stand with self-drilled holes and spacers either I assume? ^^
Reply 4 of 7, by adalbert
It should be possible to modify existing ATX bench (if it is made of acrylic) by drilling additional holes and pushing (with soldering iron) heat-set brass threaded inserts into them. Modifying metal bench is also possible, but requires more tools.
Reply 5 of 7, by vetz
imi wrote on 2020-10-27, 11:25:
If its doable to drill them yourself that could work, but best would be a flexible platform that can accept different sizes of motherboards. Been looking at
https://www.aliexpress.com/item/4001217950387 … searchweb201603_
Looks like you can adjust the positions of almost everything.
EDIT: This one maybe for acrylic type:
https://www.aliexpress.com/item/33051136133.h … searchweb201603_
Reply 6 of 7, by imi
I just got these: https://images-na.ssl-images-amazon.com/image … _AC_SL1500_.jpg
they're pretty cheap and sturdy.
got two of them for €25 iirc.
the alluminium extrusion approach is nice too, I was wanting to do that but opted to cheap out and just get those monitor stands ^^
Reply 7 of 7, by dionb
A lot of ATX cases have removable motherboard trays. Those trays invariably have AT holes as well as ATX ones. Remove the backplate and you have an L-shaped frame that will hold both baby and full AT boards. I have a pile I use for exactly that purpose.
This sort of thing:
