Reply 17000 of 30427, by bearking
Hi guys,
I'm pretty happy today!
Why?
TLDR: my "dead" ASUS P2B-LS is working just fine!
The long story goes like this...
After I built my socket 7 system based on the Gigabyte GA-586HX running a K6@233, I realized that I need a bit faster daily retro machine.
The system is great, but some of the games I've tried to run on it, seemed to be a little sluggish.
So I decided to put together a Pentium II system. I have a few slot 1 PIII OEM systems from Compaq, Siemens, etc., but I wanted something built by myself.
Also I have a few slot 1 known to be working mainboards, such as the Abit BE6, an Intel SE440BX-2, a FIC VB-601-V, a Lucky Star 6ABX2V and a couple of more... and a few PII CPUs.
For me, the first choice was the BE6, because it was my very first good mainboard. Unfortunately it doesn't like the 100 MHz bus, after a while I'm getting artifacts or no video signal at all with any AGP graphics card. Even if I set in the BIOS the AGP speed to 2/3 of the FSB speed. So, the ABIT is a no go...
I don't really like the SE440BX-2 because of it's limited BIOS. The Lucky Star board is a piece of crap, it hangs like a minute or so after POST and before booting, the IDE 1 channel is not working. The FIC board it has a VIA chipset...
Apparently I was out of options, then I remembered I have a "dead" ASUS P2B-LS rev. 1.03. Back in June I spent almost a week trying to boot up this board, without any luck! I can swear I've tried everything, but the board just didn't wanted to show some sign of life, so I've put it to storage.
In the first place I've pulled out the 450 MHz PII CPU from the ASUS board to try it out on the Intel board, but it didn't POST-ed... After I cleaned the edge contacts of the CPU, it worked perfectly on the Intel board! Then I realized how big of an idiot I am! Back in June I didn't do this cleaning step, and I guess I didn't swap CPU's on the ASUS board, after all... Rookie mistake!
Anyway, I'm am really happy that this board is working now, because it's in a like new condition and is a solid mainboard with a lot of features. Also have the IO shield, SCSI ribbon cable, parallel and serial ports for the back of the case...
For testing I've put in an SL2TV s-Spec PII 333 MHz running without issues @500 MHz(100*5), 512 Mb RAM, an ASUS AGP-V3200/16 Voodoo Banshee, a Creative SB Live! 5.1 SB0100 and a random 10 Gb Seagate HDD. For now, I think it's a good system. I will put it in a nice and simple ATX case I have from 1998, when I know it's stable.
PS: also made a great deal on a Voodoo3 2000 AGP... waiting for the package to arrive...
) as I needed that to get some of the pins inserted - they needed force, I'd rather not exert that on a motherboard.
