Shoving some SL64V celery into a slot 1
Reply 80 of 84, by PARKE
script-fu wrote on 2020-10-27, 17:08:
Thanks for clarifying that last question PARKE. Now i can put this thing back together. Did the VRM look like it will hold up to you too? As darry's post did worry me a bit as my coppermine was up in that chart and in the orange. I posted a picture a while back of the VRM.
The "VRM" encompasses the entire setup, not only the HIP chip but also the mosfets etc. I don't know enough about those issues to comment on that. I do have a motherboard here that is, according to the manual, compliant with VRM 8.4.
According to a note that I have (see below) here this translates to being able to handle 22.8 amps (which should be enough for your 1000 MHz cpu.
ooooooooooooooooooooooooooo
-VRM 8.2 1.30-2.05, 2.1-3.5 volts 16.1 amps
24377302.pdf
The attachment 24377302.pdf is no longer available
-VRM 8.4 1.30-2.05 volts 22.8 amps (Coppermine)
24533505.pdf
The attachment 24533506.pdf is no longer available
ooooooooo
But I don't know if your Gigabyte board is manufactured along the VRM 8.4 qualifications. And this stuff is all focusing on factory specifications so I am not sure if you would ever run into serious problems if you run a 1000 Mhz cpu on a board with a VRM 8.2. I have a 1000 Mhz /fsb cpu running on a board with a VRM 8.2 without problem but I must add that it is not used on a regular basis and never under stressful situations.
Reply 81 of 84, by script-fu
Thanks for those PARKE
I kinda ran into an old yahoo GeoCities site that has been interesting.
http://geocities.ws/_lunchbox/tualeron_success_table.html
https://www.google.com/search?rlz=1C1CHBF_enU … HatYB1oQ4dUDCA0
Gb GA-6BXC r.2.0 b.F4C, PIII 1.0GHz SL5QV, 768MB PC133, GF Ti 4200 64MB, VD3 2K, CT4760 & CT4860 AGP 2X
Abit KN8, 64 3400+ (754), 2x1GB G.SKILL PC3200, GF 6800GT 256MB AGP 8X
Abit Fatal1ty AN9 32X, 64 x2 6000+, 2X2GB PC6400, 8800 GTS 320MB x2 SLI
Reply 82 of 84, by PARKE
script-fu wrote on 2020-10-27, 23:58:
Thanks for those PARKE I kinda ran into an old yahoo GeoCities site that has been interesting. http://geocities.ws/_lunchbox/tu […]
Yes, I know these pages. The mod that you can apply (if you ever feel adventurous) to your two PPGA slotkets to make them Coppermine ready is relatively simple:
http://geocities.ws/_lunchbox/pentium3_socket370_mod.html
Reply 83 of 84, by script-fu
PARKE wrote on 2020-10-28, 04:49:
I think i'm gonna pass but i do have the stuff here to pull it off.
I did get the computer all put back together and all seems to be fine. I'm struggling with the SSHD at the moment if i haven't hosed it. My little 32GB removable SD is really old and i need to get a new one. After those kinks are worked out. I think i'm golden
Win98SE complete build log
Gigabyte GA-6BXC Rev 2.0 ( v.F1 to v.F4C Beta Bios 10-10-20 )
SL5QV 1000/256/100/1.75V Coppermine PIII 370-pin FC-PGA
Fast Fame 370SPC PIII SlotKet Adaptor
3 x 256MB Sticks of Crucial PC133
GeForce 4 Ti 4200 AGP Video Card
Creative Sound Blaster Live CT4760 PCI w/ Live Drive CT4860
Seagate FireCuda 1000GB Internal 3.5" (ST1000DX002) SSHD
PATA IDE to SATA Adapter
SD to IDE HD Adaptor w/8GB & 32GB SD Cards - Win98SE on Both
Plextor PX-716A IDE DVDRW w/ Black Face - Find the White Face
Kenwood UCR-411 True-X 72X IDE CDROM
Echo Star 580W 20+4 Power Supply
Generic White Pacman ATX Case
Reply 84 of 84, by script-fu
I just want to thank all involved in this crazy thread! I really really appreciate everyone's help. < closed />
