Unrealcpu wrote on 2020-11-02, 15:15:thanks i like your data base.. […]
dionb wrote on 2020-11-02, 09:03:Take a look here:
https://stason.org/TULARC/pc/sound-cards-mult … R-PRO-2-CT.html […]
Unrealcpu wrote on 2020-11-02, 08:44:
https://linksharing.samsungcloud.com/DEBaqLu25bhN
ok here is a photo of my sb card
i am prettu sure it is set to irq 5 what is the other jumpers set too?
Take a look here:
Comparing that to your pic (very fuzzy, so can't be 100% sure):
JP5/6/7: 6 DRQ 1
JP15/16/17: 16 DACK 1
JP18/19/20/21: 20 IRQ5
JP11: 2-3 DMA sharing Enabled
JP4: on Game Port Enabled
JP13/14: 13 - A220
That is pretty much the default setting I'd expect on a CT1600.
Then in autoexec.bat you need corresponding settings:
SET BLASTER=A220 I5 D1 T4
SOFTMPU .EXE /SB:220 /IRQ:5 /MPU:330 /OUTPUT:SBMIDI
Finally in your games you need to select MIDI IRQ 2 or 9 (NOT 5), Address 330.
That should work - although I can't test it for you as I don't have a CT1600.
great source of info
I am still having issues with ultima 6 not working and wing commander. I am getting no sound or barley coming out from my speakers. Cables are setup correctly... I did have sound coming out of IRQ7 DMA1 , 220 ,
sound works fine in regular dos games though. I know phils computer lab mentioned you have to set sound in drivers using sbproset or mixer software to turn up the midi
MT-32 shows playback working in each game scene on display.
No drivers are installed and used the settings above for autoexec.bat.
what the heck am i doing wrong? Thanks
photos of my dip switches. Only thing installed is this sound card.
https://linksharing.samsungcloud.com/LeJF97yDBtVN
I assume you are routing the MT32's out to the SB Pro's line-in. If so, you need to enable the line-input using sbp-set.exe
Running SBP-SET /M:15,15 /VOC:15,15 /CD:15,15 /FM:15,15 /X:0 /LINE:15,15 should do it .
- Each channel (left and right) is controlled independently and goes from 0 (quietest) to 15 (loudest)
- This assumes that you are using CD audio input as well, otherwise set CD to 0,0 . Adjust to taste .
- "X" is for the mono microphone in, hence the sing digit .
- This is largely from memory, with a little help from Google, so if this is not 100% accurate, I suggest check your card's docs to very syntax .
EDIT : If this does not work as expected, I can always check on my retro rig, but I do not currently have an actual CT1600 .
AFAICR, some games RESET mixer settings , including muting inputs, but Ultima 6 is too old to even know what an SB Pro is . It is something to keep in mind for other games .
