Reply 36781 of 53146, by matze79
imi wrote on 2020-11-07, 00:07:
and this oddity I absolutely had to have x3
Ah nice PC-104 ISA VGA
Reply 36782 of 53146, by Thermalwrong
some random stuff... YMF card with QDSP1000, needs a good bath ^^ Aztech Sound Galaxy BXII […]
Yamaha DB50XG :3
Wow, PC/104 video card, that's definitely rare.
PC104 stuff, especially useful PC104 stuff like audio or sound, is so tough to find I ended up making my own PC/104 to ISA adapter board. Nice DB50XG too 😀
Reply 36783 of 53146, by Aublak
I bought this TNT2 Ultra, Speedstar VLB, and a Daewoo socket 3 board from my e-waste guy.
I guess the Daewoo mobo is a CPC-2900, but I'm not finding much documentation on it.
No heatsink on the TNT2 Ultra unfortunately. Fan power header tells me that the fan is probably unique on this.
mpe wrote on 2020-11-06, 14:09:
Got two 486 DX2-66 overdrive CPUs. ODPR version and ODP (the one with extra pin everybody seems to be so confused about): […]
What's the difference between these overdrive chips and regular DX2s?
Reply 36784 of 53146, by PD2JK
Put something like a Zalman NB 47J on it if you have enough airflow in your case.
Reply 36785 of 53146, by keropi
that speedstar with the Trio64 chipset must be an awesome VLB card, kudos!
Reply 36786 of 53146, by Salient
pan069 wrote on 2020-11-05, 09:05:
Nice. You must have paid a pretty price for that? I'm glad I never sold mine, although I've lost other hardware over the years (moving around). I have the exact same card. I think I got it in late '94 and it currently sits in my 486/100 build next to a CT1740.
My Gravis Ultrasound and 16 bit daughter board
In fact it came as a 'package deal' together with a Roland RA-50 and I paid a lot less for the bunch than the current lowest "buy now" price (edit: it's actually bidding) for a GUS on ebay (which is 125 euros starting price for a 256kb rev 2.4 version).
I am planning to have it sit next to my awe32 ct3900.
Reply 36787 of 53146, by imi
Thermalwrong wrote on 2020-11-07, 15:16:
yeah, it's the first time I even found a "normal" PC/104 VGA board.
...and yes I've been listening to the DB50XG all day with the Tyrian2000 jukebox ^^ had to swap the sound card in my current 386 setup as the CT1740 was refusing to output sound through the wavetable... CT2910 was the quickest at hand without me having to change any settings and seems to work fine :3
Reply 36788 of 53146, by SVD
Got 2 computers and 3 crts today.
Both computers are 486.
The desktop have dx33, Trident 9000 vga, full size AT psu, caddy CD rom and a SB 2 pro 😁
The baby AT tower have dx4-75 overdrive and CL 5428 VLB 2mb
The mainboard are damaged, anyone know what happened? There is no caps who look damaged in the area.
CRTs
Dell p992 19" trinitron (happy about this one 😁)
Hitachi CM 625 17"
Forefront vm-1400 monocrome
Reply 36789 of 53146, by chrismeyer6
That corrosion you see is from a leaking bios battery. Your best bet is to cut the batteries off and give the boards a good once over with some white vinegar and a toothbrush and then a nice rinse in distilled water.
Reply 36790 of 53146, by Robin4
keropi wrote on 2020-11-07, 17:00:
good for dos?
Reply 36791 of 53146, by SVD
chrismeyer6 wrote on 2020-11-07, 22:18:
No it's not, the battery is a long way away and is a cr button type that is looking good.
I did clean it some with alcohol. But i guess i have to take it out and inspect the traces. Could those tantals leak and still look okay?
The board is a FIC 486-pvt
Reply 36792 of 53146, by keropi
Robin4 wrote on 2020-11-07, 22:28:
good for dos?
one of the fastest chips for dos AFAIK
Reply 36793 of 53146, by TheMobRules
keropi wrote on 2020-11-07, 22:48:
good for dos?
Yes, pretty much the best VLB for DOS when you take into account both speed and compatibility, when matched against other "high-end" cards such as the ET4000/W32P. I dont't have an ARK1000 VLB (which is said to be the fastest) to compare, but my Trio64 VLB is a bit faster than an ARK2000 PCI when using the same 486-class CPUs.
It also has the best image quality of all my VLB cards, despite having an integrated DAC.
Reply 36794 of 53146, by EvieSigma
I've had this for three days now but only got around to actually testing it tonight...this is a most cursed PC indeed. Hardware wise it's just a Micron Pentium 66MHz desktop (albeit with a rather nice Diamond Stealth32 (Tseng ET4000) video card and a SoundBlaster 16 CT2910) but...someone along the line gave it this truly bizarre spatter paint job on almost all the plastic parts of the case. That and it has a messed up Windows 95 install with various things that are just straight up missing, like...all of Plus's desktop themes, for example. This thing is going to be a fun project.
Reply 36795 of 53146, by PD2JK
EvieSigma wrote on 2020-11-08, 04:02:
I've had this for three days now but only got around to actually testing it tonight...this is a most cursed PC indeed. Hardware […]
Nice. Socket 4 or 5? Check if it has the FDIV bug. 😁
Reply 36796 of 53146, by EvieSigma
PD2JK wrote on 2020-11-08, 05:10:
Socket 4! As for the FDIV bug, that will have to wait until after I wipe and reinstall 95 as the current install just is not usable with how...mangled it is.
Reply 36797 of 53146, by Aublak
Something I forgot to post earlier.
CL GD5424-80qc vlb
You can't see it, but the pcb has a metallic green sheen on it. Its a really spectacular looking card.
    1.74 MiB
    cl gd5424-80qc vlb
Reply 36798 of 53146, by vmr_
debs3759 wrote on 2020-10-05, 22:58:
EvieSigma wrote on 2020-10-05, 22:50:
Got these two motherboards from a website called Alltronics (can't find the thread about them, did it get deleted/moved?)
Looks like it was deleted. Glad I saved the url 😀
Hi Debs, mind sharing the URL? PM ok? Thanks
Retro builds & sandbox
IBM XT 5160 | 286 | 386 | 486 | S4 SI5PI AIO & S4 Batman + P60 SX828
S8 & PPro 200 | SS7 FW 5VGF & Asus P5A & AOpen AX59PRO K6-III+ 550MHz
Asus K7M Athlon 1Ghz GDF | Abit SH6 Pentium III 1GHz SL4KL...
Reply 36799 of 53146, by mpe
Aublak wrote on 2020-11-07, 15:41:
The ODPR is practically identical. The ODP is meant to be installed in the overdrive socket. It has one extra pin (to avoid it being inserted incorrectly into the socket). It also has UP pin outputing low signal so that it can disable the other CPU if still present (such as when soldered on the motherboard). On standard DX2 this pin is input waiting for the signal from the overdrive CPU.
Blog|NexGen 586|S4
