First post, by Almoststew1990
Almoststew1990
Offline
- Oldbie
I have an 81GB IDE drive. My BIOS sees it as 81GB and I enabled LBA mode, and POST confirms that. If I installed XP it works fine.
But I want to use Windows 98. I use fdisk that comes with the Windows 98 set up disk to create the partition and it only partitions 12GB. I try to create a extended partition and it says there is no space to do that.
Any ideas?
If I enable the 32GB mode thingy will that at least give me that much space ?
This is on a Socket 478 system
