First post, by Hanamichi
I said I would test this a while back but I had put it aside waiting to finish a build or two.
I did a brief post test which was fine.
1.89 MiB
Videologic R-Cade Vision 250?
1.54 MiB
Videologic R-Cade Vision 250? IO
I contacted Imagination Technologies and although I did get through to someone, they didn't get back to me (understandable).
I've never seen a Neon 250 with TV-Out or any literature but had read an arcade version existed.
Today I found this article in PCPowerplay 1999, the only image of an R-Cade Vision 250 I have seen and it is similar to this card.
Apparently supporting 15, 25 and 31KHz. Which now makes sense as there are two dip switches like an EGA card.
It also mentions a daughter master board to attach for controllers but this was not in the lot I purchased.
241.65 KiB
PCPowerplay-035-1999_page134
https://archive.org/details/PCPowerplay-035-1 … de/2up?q=r-cade
Background:
I picked this up from eBay US over a year ago after envying the few neon 250s on this forum. I thought I would never own one.
It was in a scrap pile, could not believe my luck. I used the search term "NEC AGP" in blind hope. (It hasn't worked twice)
Realizing now it was probably a prototype for an arcade system I tried to check my ebay purchase history for the original seller but it's gone sadly.
Reply 1 of 1, by Hanamichi
Been keen to test but nervous about attaching a heatsink (there are no through holes)
Does anyone recommend a temporary thermal adhesive?
I have bought some silicon thermal glue (not epoxy!) and these https://www.startech.com/en-gb/computer-parts … eviews--section
Both products are poorly rated for their adhesion and performance but that's good for me to protect the card from damage when removing the heatsink.
Also is an 815P chipset guaranteed to be AGP 3.3v compatible? My AOpen board does not specifically mention it but I assume it is. I do have a sacraficial TNT to double check.
