Reply 17120 of 30429, by wiretap
- Oldbie
Tore apart my Commodore 1084S tonight.. replaced all the transistors in the Green video circuit on the neck board. (I have no green output) Checked for dry solder joints and all passive components and electrolytics and wires. No issues there. Plugged it back in, and still no green color output. 🙁 So, I just ordered a Philips TDA3507 to see if that will do the trick. At least the thing is easy to take apart.
