First post, by hard1k
Hello everyone,
As we're approaching the release of our AWE64 Legacy project, I've decided to start some arrangements for the next one.
This time it will be my all-time favorite brand and product, the almighty Aureal Vortex2 (AU8830), the last game changer in the computer audio industry.
The first idea is to make an "A3D-accelerator", a very small PCB with no bracket, and just two MPC connectors (Line-In and Line-Out) so that it could be installed in tiny systems, thin clients or PCI/ISA shared slot along an ISA card occupying the bracket place.
What would you guys suggest? A new soundcard? What should it be? Or a combo with anything else? Do any of you have any hardware-related docs, a detailed datasheet, for example?
So, the general preliminary product concept will be as following:
300.06 KiB
FIRST MAJOR UPDATE
SECOND MAJOR UPDATE: we have already designed the PCB, sourced all the necessary parts, produced the first prototype (albeit a buggy one), fixed the identified bugs and ordered the second prototype!
510.63 KiB
497.71 KiB
THIRD MAJOR UPDATE: all PCI devices (TI PCI-PCI bridge, AU8830, YMF744) have been detected by the host system, looking forward to testing results by jheronimus!
1002.41 KiB
1.03 MiB
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 1 of 112, by Paar
I don't know, I'm kind of a sucker for high end cards so I'm not very excited about the budget variant. Any Aureal card should have wavetable header for example (my opinion). Now when I'm thinking about it, is it possible for Aureal card to support PC-PCI link? That's the one thing I am missing from most DOS capable PCI cards and I don't recall I have seen it on any official Aureal card.
Reply 2 of 112, by hard1k
In fact, existing cards offer a nice variety of higher end options: SQ2500, SuperQuad, Turtle Beach Montego II Home Studio, etc.
And all of them are available and not so expensive, so I don't see a reason for a new card replicating the existing set of features.
That's why I'm thinking about niche use cases, or some combo cards.
No, unfortunately Aureal chips don't provide for PC-PCI (or I am unaware of this, as it hasn't been mentioned anywhere), nor is there any comprehensive reading about their hardware side of things.
AWE64 Legacy
Reply 3 of 112, by crvs
IMO biggest drawbacks of Vortex cards were rather related to drivers, especially for DOS and Win 2k+. There was a promising thread in this forum dedicated to development of an alternative DOS driver - not many recent updates unfortunately, however, some documentation is mentioned there, and the topic starter may also have deeper understanding of the subject.
Speaking about hardware, I'd also say that Aureal's simulated FM synthesis sounds pretty poor (way worse than CQM), if no beter driver - here is the place where true OPL could be even more beneficial. Compatibility could be also improved: original cards are quite picky to PCI slots and prone to conflicts with other adapters, and I still recall pain with VIA chipsets 20 years ago, though already w/o details.
Nonetheless, I still somewhat like Vortex2, so good luck and interesting to see which direction your project takes.
Reply 4 of 112, by matze79
i anyway would not play early titles with adlib sound on such machines, instead going to put a wavetable on the header and use general midi then.
Co2 - for a endless Summer
Reply 5 of 112, by hard1k
Well, in the past I already considered making an "Ultimate" PCI sound card (YMF7x4+AU8830 behind a PCI bridge, interconnected via SPDIF) but finally decided to discard that. In my perception, AU8830 is only useful in A3D 2.0/3.0, it's where it shines. It won't suit for a good DOS card (there are better options, YMF7x4 and Solo-1), or an audiophile grade card, and would make for a mediocre all-round card due to the mentioned bad FM implementation, buggy Win2K/WinXP drivers, compatibility problems. So, to be honest, AU8830 should be used only in Win9x (so, no SMP or 512+ Mb of RAM), for playing A3D titles (but hey, there are lots of them, and many of them are A+ ones!), so the CPU power should be decent too (P3-600 at least) as A3D has its impact on the performance. That's why I'm thinking about this specific A3D Accelerator niche.
AWE64 Legacy
Reply 6 of 112, by cyclone3d
Check these out:
http://web.archive.org/web/*/http://galadriel … der/aureal/re/*
http://web.archive.org/web/*/http://galadriel … ureal/techdoc/*
Looks like Aureal had at least some emblance of a datasheet, but I can't find it for download anywhere:
http://www.aureal.com/newaureal/products/pdfs … ortex_final.pdf
Only thing I could find is the readily available preliminary overview datasheet.
Yamaha YMF7x4 Guide
Reply 7 of 112, by hard1k
cyclone3d wrote on 2020-11-14, 21:52:
Been there, seen that, thanks! I've also found out that guy took part in the OpenVortex project (Linux OSS & ALSA drivers), besides he lives "nearby" (in Chile), so I'm already thinking to try contacting him when all this Covid stuff is over, would be fun to fly there and meet 😀
Judging from the filename, I guess that's the same preliminary datasheet (attached) - it's header is the same, "8830 Vortex FINAL".
    DSA00513971.pdf
    108.44 KiB
    67 downloads
AWE64 Legacy
Reply 9 of 112, by hard1k
Guys, a serious question - as we'll be designing a new device, we can change the codec chip for a better one.
I'm a noob in codecs, tried to google a bit, there's a load of them available, tried to remove false positives, got to this: http://manuals.opensound.com/sources/oss_ac97.c.html (what can be better than the source code for some linux stuff, right?)
Got the following list from the mentioned source code:
AK4540, STAC9700, STAC9701, STAC9721, STAC9704, STAC9705, STAC9708, STAC9744, STAC9750, STAC9752, STAC9756, STAC9766, STAC9758, TR28028, TR28023, EM28028, CX20468, CS4297, CS4297A, CS4294, CS4299, CS4202, CS4205, AD1819B, AD1881, AD1881A, AD1885, AD1886, AD1887, AD1888, AD1980, AD1981, AD1981B, AD1985, WM9701A, WM9703, WM9704, ES19XX, ICE1232/VT1611A, VT1612A, VT1616, VT1616A, VT1618, ALC100, ALC200P, ALC202, ALC203, EV1938, ALC250, ALC650, ALC655, ALC658, ALC850, CMI9738, CMI9739, CMI9761A, CMI9780, YMF743, YMF753.
The guys from OOAOO used WM9704 for their MX300 Ultra card. What do you think, what is the better option?
AWE64 Legacy
Reply 10 of 112, by matze79
Just keep vortex 2 it’s a great card I like the idea
Reply 12 of 112, by Oetker
kolderman wrote on 2020-11-15, 06:09:
What about a new ISA card based on the als100? It's a good chip often put on crappy cards.
Yes I hope someone builds just that.
Reply 13 of 112, by hard1k
matze79 wrote on 2020-11-15, 05:06:
It will be Vortex2, but any Vortex needs an external AC97 codec (that little square chip), and as we're making a new design, we can put any chip we like, that's why the question. Back in the day Aureal could be cost-cutting on the codec to save a few bucks, but now it doesn't matter, I'd prefer to take a better part with better SNR, etc.
AWE64 Legacy
Reply 14 of 112, by firage
The codec on the old cards was the same as on the Live 5.1, surely put a hard limit on the quality you could get.
Wonder if there's something that could be improved in 44.1 kHz resampling in Vortex2 cards; I don't know anything about how it's implemented.
My big-red-switch 486
Reply 16 of 112, by hard1k
Yes, many of them do. I also find good words about Sigmatel (namely, in the YMF7x4 FAQ) and Wolfson (articles on the net + feedback on different iPod generations, etc).
Would be cool to receive some feedbacks on specific parts though.
AWE64 Legacy
Reply 17 of 112, by Tiido
The chip has I2S input and output, you could simply drop the shitty codec chips and use modern DAC and ADC instead (lacking mixer though). There's probably some driver change needed to achieve it though...
Reply 18 of 112, by hard1k
Tiido wrote on 2020-11-15, 18:26:
That's exactly the reason why I opt for the codec... We still lack a coder in our team, a simple dirty hack always requires lots of efforts and other people involvement 🙁
AWE64 Legacy
Reply 19 of 112, by gex85
hard1k wrote on 2020-11-14, 19:38:
At least for Germany and probably most of western Europe, this is not really the case. Pretty much all Vortex2 cards are rare and expensive.
Vortex 1 cards are easier to come by, but still sell for >20€, usually. So that's not exactly expensive, but not as cheap as all the sub-10€ Audigy2 ZS cards that pop up every day.
That being said, Diamond Multimedia made the Sonic Impact S90, which is not as crappy in quality as many other AU8820 cards, so if retrofitting the AU8830 chip to an AU8820 design is actually an option, this might be a good candidate.
My retro computers
