First post, by StaffelGuard1917
Hello, people ! Can't run normally that great game on any system, real h-w. Tried on a p1 system in win 95 environment - runs too fast. Tried on a 486DX2-66 it won't run as didn't find enough memmory , even if I use memaker and unload all unnedeed drives - tried it's own boot disk system files, but then it doesn't allow to load mouse drivers as if I do so it again writes it "doesn't have enough ram..." mouse driver I have is a4mouse5.com and it takes about 4kb of ram... Maybe I have to install win95osr2 at 486 system ti run it from there...[*]
Reply 1 of 1, by Jorpho
Don't you think it would be easier to help you if you provided your autoexec.bat and config.sys?
By far the easiest solution would be to use Exult.
http://exult.sourceforge.net/
It is very surprising that you can get the game to run at all under Windows 95. Normally that requires, U7win, also known as U7run. That might help you.
https://web.archive.org/web/20070818142830/ht … 7inWindows.html
(Note that many of the details on that page are out of date and you should not try to use VDMSound for anything anymore.)
