Slot-2 dimensions
First post, by H3nrik V!
Hi All,
Anyone know of a data sheet for slot-2 connectors (the connector, that the Slot-2 Xeon goes in) ? I'd like to make a 3D model of it to keep a couple of Xeons in a display case.
If not, would anyone mind measuring one? ๐Ÿ˜€
If it's dual it's kind of cool ... ๐Ÿ˜Ž
Please use the "quote" option if asking questions to what I write - it will really up the chances of me noticing ๐Ÿ˜€
Reply 1 of 4, by computerguy08
I think it would be easier to measure the CPU contact itself. You'll likely need to make a few test pieces to get the gap right anyways.
Reply 2 of 4, by H3nrik V!
computerguy08 wrote on 2020-11-16, 15:00:
True that, I've also found the datasheet for the actual processor with those dimensions, but would be kinda fun to ensure that what I mount it in, would look like a real slot-2 slot .. ๐Ÿ˜€
Reply 3 of 4, by PC Hoarder Patrol
H3nrik V! wrote on 2020-11-16, 15:32:
http://db.zmitac.aei.polsl.pl/Electronics_Fir โ€ฆ gd/24442801.pdf
Reply 4 of 4, by H3nrik V!
PC Hoarder Patrol wrote on 2020-11-16, 21:50:
That's perfect, thanks!
