WP32 McCake : MT32 compatible waveblaster board
First post, by dreamblaster
Here is another project : WP32 McCake
Waveblaster compatible card containing :
- good quality DAC, careful analog part
- micro sd card slot for your software and legal MT32 rom binary backup
- power circuitry including protection and dual option :
- power through waveblaster header (solder bridge)
- power connection for floppy power
- compute module 4 for running Munt or other synth
- header to connect drive bay panel
EDIT 28/12/21 : added new images, added shop link, added panel link info :
https://www.serdashop.com/WP32-McCake
    47.8 KiB
    McCake production version
    17.83 KiB
    5.25" panel
    17.65 KiB
    3.25" panel
    77.44 KiB
    McCake original prototype design
Thanks for your support !
Reply 2 of 424, by darry
dreamblaster wrote on 2020-11-16, 18:02:
Here is another project : WP32 McCake […]
I hope to have prototypes in december
Very nice!
Reply 3 of 424, by Salient
...Sigh..... ok, take my money... again.....
Reply 4 of 424, by cyclone3d
Sweet! I want one already.
Would be even better if it had a way to hook up an LCD that could be set on the outside of the computer to display the messages like a real MT-32
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 9 of 424, by dreamblaster
kolderman wrote on 2020-11-16, 23:01:
Needing softmpu?
Not on keropi's MPU card 😉
Reply 13 of 424, by Cyberdyne
Well that I will buy, because you can emulate other MIDI devices, load your own sound banks in the SD card, possibilities are limitless.
Reply 15 of 424, by Tree Wyrm
Ah, MT32 emulator via RPi on waveblaster board. Ought to be quite useful considering MT32s continue to rise in price. Even though I have one I still want this one, if only to tinker with it. What's next, CM-500 on WB? Like this with Yucatan FX in one board (and sysex to switch between MT32 and GM perhaps)? On the other hand I guess running SC VST is also an option, doesn't have to be just MUNT.
Reply 16 of 424, by matze79
also add rs232 header to connect to computers interal rs232 header so you can use console from retropc too, or serial tcp/ip link ?
Does RPI 4 have 2 Uarts ?
I like it it looks really Great!
Reply 17 of 424, by dreamblaster
Design ready, hope the prototype will work
    63.23 KiB
    84.59 KiB
    75.91 KiB
