First post, by Dave Bursik
Hello.
I have problem with motherboard Unichip 386WB. I tried to test this motherboard by booting to the BIOS, but if I turn the computer ON, leds blink on the keyboard and then I get theese messages.
CMOS checksum failure
CMOS display type mismatch
Keyboard error
Any idea what is wrong? Because of keyboard error I cannot go to the BIOS menu. 😕
Pictures are attached.
Thanks.
Reply 1 of 10, by debs3759
Could the errors be fixed by replacing the missing battery?
Reply 2 of 10, by quicknick
Or there could be some traces going to the keyboard connector eaten by corrosion from the old battery; please post a close-up picture of that area.
Reply 3 of 10, by konc
I have the same with a really tiny amount of battery leak and it needed a trace repair with the exact same symptom. So yes pay attention to the area around the battery, bottom side included.
I hope you fix it, it's a pretty fast motherboard.
Reply 4 of 10, by Dave Bursik
many thanks for your help. I check again all way repaired before and found one problem around choke L4. I repaired it. Now it is working 😀 Im really happy 😀
Photo is attached.
By the way .. Does anyone have an original User´s manual for this motherboard? I found this link where the manual could be downloaded, but I don't think people are active anymore.
http://www.amoretro.de/2012/02/unichip-367c-u … otherboard.html
Thanks a lot again,
David
Reply 5 of 10, by pentiumspeed
I can see a solder trail shorting two leads of transistor exactly besides the battery holder.
Cheers,
Great Northern aka Canada.
Reply 6 of 10, by Dave Bursik
pentiumspeed wrote on 2020-11-18, 20:06:
Cheers,
Hi, thanks for your replay. Can you mark it on the photo?
Thanks, David
Reply 7 of 10, by pentiumspeed
I said right besides the battery holder (dead center of holder's) on solder side.
Cheers,
Reply 8 of 10, by Dave Bursik
pentiumspeed wrote on 2020-11-18, 21:05:
Cheers,
Im sorry. I dont know what you mean... I cannot see it.
David
Reply 9 of 10, by debs3759
I can see two potential shorts
