Reply 20 of 81, by vasyl
Regarding SS Enhanced:
Okay - oddly enough, the 640x480 resolution is only marginally slower than the 320x200 one. The 800x600 res crashes DOSBOX.
You are running regular 0.65 build, right? Can you try that [800x600] with ykhwong's build? I am just curious if it is something my patch fixes -- I've seen the issue in some apps (like whatvga) but I haven't seen it in games yet. That was actually expected, the issue was most likely for highres games and most of these were not playable until recently.
