DOSBox and PLC software
Reply 20 of 23, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
> http://www.ctyme.com/intr/int-14.htm
That's what I'm working with 😉
I assume your hardware has nothing to do with the commodore then...
> "speak" with a I/O com
Not possible. Though if the card only uses I/O-ports (no interrupt/memory/DMA) Dosbox could be modified to access them. Like in my parallel port passthrough patch. But Dosbox in not a real time operating system and you'll have to find somebody to do the modification.
1+1=10
Reply 21 of 23, by Sheltem
Time for me to move departments i'll get my replacement to run the diagnostic build and post it here. Thanks for you help so far especially Hal!
Reply 22 of 23, by kezman
Hello all,
I have taken over from Sheltem, i ran the diagnostic build and DOSBox Status Window came up with the following:
Ser1: RTS off
Ser1: DTR off
Ser1: RTS on
Ser1: DTR on
these 4 lines were repeated numerous times (approx 10) before the actual timeout occured
Reply 23 of 23, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
That's less than I hoped for... I think I'll bring up another one...
1+1=10
