First post, by BEEN_Nath_58
Today I got back to playing Resident Evil 3 Nemesis at 1280x1024 resolution but the textures became blocky. I turned to Windowed mode too, but no change occurred. On lower resolutions like 640x480, the problem doesn't occur. Could anyone please help with what is happening? I had earlier played at 480p and never changed the resolution since I never knew about it, so I this is my first time with this problem.
View the image in full screen to see the blocks.
Reply 1 of 10, by xcomcmdr
The problem exists since day 1 on this game.
I've played it on various hardware (Voodoo 3, GeForce 4, ...) and Windows versions (Windows 98SE, XP, Vista, Seven, Windows 10), I *always* had to play in 640x480.
Reply 2 of 10, by BEEN_Nath_58
xcomcmdr wrote on 2020-11-25, 08:16:
They probably never looked it into it then. I thought the Voodoo2 option in the Others tab will do somethinf but it did nothing,expected it to use Glide.
Do you know what it does btw?
Reply 4 of 10, by xcomcmdr
The Voodoo2 option fixes the blocky blood displayed by buggy Voodoo 2 display drivers, according to the manual.
The game always uses Direct3D 6.
Reply 5 of 10, by BEEN_Nath_58
xcomcmdr wrote on 2020-11-25, 20:41:
Though of using 480p in game and force higher resolution through dgVoodoo. Looks like the textures are the problem as it still exists
Reply 7 of 10, by Focz
Discrete_BOB_058 wrote on 2020-11-25, 07:44:
I had that problem and I solved it by disabling the texture correction option
Reply 8 of 10, by Deffnator
Gemini is working on a patch to fix it, but he is occupied looking at releasing RE2's patch
Reply 9 of 10, by Crimson Tibbasim
I had similar issues with this before. Yet, I've always blame the drivers for doing this kind of distortion.
