First post, by Steapa
Solved: This board (Zida 4DPS ver 2.1) does not support EDO memory, only FPM.
Thank you SSTV2 and bloodem.
Some time ago I found this motherboard at a recycling center:
It came with the 486 CPU and I paid almost nothing for it. So I added some RAM I had laying around, an ISA VGA, a controller card and I tried to make it post. But this is what I'm getting:
Sorry for the quality. Here what it says:
Award BootBlock Bios v1.0
Copyright (c) 1995, Award Software, Inc.
BIOS ROM checksum error
Keyboard error or no keyboard present
Detecting floppy drive A media...
Drive A error. System Halt
When I have a keyboard and a floppy controller I only get a checksum error and this:
INSERT SYSTEM DISK AND PRESS ENTER
I asked about it on Reddit and I got lots of suggestions. One of them was to add a CMOS battery, so I did it but nothing changed. A kind soul found the motherboard manual for me and told me to check the jumpers, I checked it and I can't see anything wrong with it:
https://web.archive.org/web/20191111225419/ht … es/4dps0210.pdf
Another suggestion was to clean the ROM socket and its legs with 100% isopropyl alcohol, I also did it but again nothing changed.
I also replaced the RAM and checked if it could be something wrong with my AT PSU, but I couldn't find anything.
They also told me to replace the caps, but I don't have a soldering iron either spare caps. I'm a bit dumb and I have no soldering skills, so I'm afraid of doing this right now.
There's anything else I could do? Here are more images of the board:
That's the new battery I added. The jumper setting J6 is set to "CMOS memory normal operation". When I set it to "CMOS memory clear" nothing would happen.
Some jumper settings
More jumper settings
First pair of RAM sticks I used
Second pair
I remember seeing a thread here of a guy solving this issue by using FPM ram instead of EDO, but I don't know if that is my case.
Any help would be great. I really want a 486 with PCI slots.
Thanks.
Reply 1 of 19, by konc
Sorry if this obvious but it wasn't clear from your description so I just wanted to make sure: after adding the missing battery, did you enter the BIOS to define your floppy drive? Also the m/b appears to have an IDE & floppy controller, you don't need to add one
Reply 2 of 19, by Deksor
Well maybe the BIOS chip itself is really having a problem ? It's rare but it can happen.
Try to flash a new chip using one of the bioses available here http://www.win3x.org/uh19/motherboard/show/5805
Reply 3 of 19, by Steapa
konc wrote on 2020-12-02, 17:49:
I can't enter the bios.
Deksor wrote on 2020-12-02, 17:51:
What do I need to flash the bios? Sorry if that's a dumb question, I have no idea how to make this.
Reply 4 of 19, by SSTV2
You must use FPM RAM, this board does not accept EDO.
Reply 5 of 19, by bloodem
Steapa wrote on 2020-12-02, 17:54:
You will need this EPROM/EEPROM programmer: https://www.ebay.com/itm/XGecu-Programmer-TL8 … 872.m2749.l2649
And one of these EEPROM ICs: https://www.ebay.com/itm/1PCS-W29EE011-15-W29 … 872.m2749.l2649
OPTIONAL: If you want to try and flash the original BIOS IC, you will also need a UV EPROM Eraser: https://www.ebay.com/itm/Ultraviolet-Light-EP … 872.m2749.l2649
I just did it a few weeks ago on the exact same board that you have (the Zida 4DPS ver 2.1) 😀 I should mention that mine didn't have the issue that yours has, I simply wanted to update the BIOS to a newer version.
SSTV2 wrote on 2020-12-02, 18:02:
Well, in my case it works with some EDO sticks, but it's extremely unstable. So, yeah, FPM is a must.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 6 of 19, by Steapa
bloodem wrote on 2020-12-02, 18:04:
You will need this EPROM/EEPROM programmer: https://www.ebay.com/itm/XGecu-Programmer-TL8 … 872.m2749.l2649 […]
Thank you
Can you confirm what SSTV2 said? Does this board only support FPM ram?
Reply 7 of 19, by drosse1meyer
This may sound dumb, but have you tried setting the bios CLR jumpers and booting the system? EDIT nvm just saw some text between the pics.
Also, boy they went sticker happy on those chips 🤣
BIOS ROM checksum error would indicate to me that the BIOS is corrupted in some way. Since you've already removed, cleaned, and reinstalled the chip, maybe the rom chip is faulty, or the code itself... you could try re-flashing the BIOS, which is why I imagine its asking you to insert a floppy disk
Reply 8 of 19, by bloodem
Steapa wrote on 2020-12-02, 18:07:
Thank you
You're welcome!
Already confirmed 😀 See my previous post, I edited it before you replied.
Reply 9 of 19, by Steapa
bloodem wrote on 2020-12-02, 18:11:
Thank you
You're welcome!
Oh, thanks again.
I'm going to buy FPM ram then. I will post here if it works.
Reply 10 of 19, by SSTV2
Only PR revision of that SIS chipset support EDO RAM, older revisions will cause that "checksum" error at boot, though with some fast EDO ram sticks it might POST, but don't expect anything more.
Reply 11 of 19, by drosse1meyer
Looking at the manual it appears this mobo has a jumper JP4, for EEPROM vs Flash rom selection, in between two PCI slots... Wonder if OP checked that's set right?
Reply 12 of 19, by drosse1meyer
SSTV2 wrote on 2020-12-02, 18:21:
INteresting... I guess problem solved! (hopefully)
Reply 13 of 19, by Deksor
Where did you get that info ? I'm curious 😁
Reply 14 of 19, by Steapa
drosse1meyer wrote on 2020-12-02, 18:35:
Yeah, I checked it nothing changed.
I just bought some fpm ram sticks, but it will take three to four weeks for it to arrive 🙁. I was looking forward to spending my Christmas playing lemmings on this machine.
Reply 15 of 19, by SSTV2
Deksor wrote on 2020-12-02, 18:45:
VOGONS and personal experience 😁
Reply 16 of 19, by drosse1meyer
Steapa wrote on 2020-12-02, 18:52:
Maybe Santa will come early 🤣
Reply 17 of 19, by Deksor
SSTV2 wrote on 2020-12-02, 18:54:
Well i don't know which kind of RAM I used on my 4DPS, but I think that was EDO, I'll try that since mine isn't the rev you described 😁 (and also that the datasheet for that chipset from 1995 states that EDO is supported)
Reply 18 of 19, by Steapa
My memory arrived, switching to FPM indeed solved the problem. Thank you, everyone.
Reply 19 of 19, by bloodem
Glad it's working for you now! It's a great board, enjoy it 😀
