First post, by Robin4
- l33t
Hello all
Iam looking into a solution for quick compact flash storage as backup . ( i dont havent an other solution to do so) (bare motherboard with cpu + memory + graphics card+ controller card installed)
So i can install the ISA card and using it as a SLAVE drive near my old IDE 504MB harddisk so i can copy over the files to the flash card and using it as a backup device where i can make copies of the software of that compact flash card.
I see a lot compact flash isa cards on ebay.. But dont know which i would purchase.. I know i could choose for a cheaper build up one, but iam insure if the adapter would run in slave mode.. (normally they act as a MASTER device)
Maybe here are people owning one and knowing for sure that the isa CF they are owning can be set as slave drive..
Which one would you recommending me?
