First post, by Kanto
About the only directory I can get to work is c c:\windows, and that's not what I want. I followed a step-by-step thing for playing old games with a DOSbox, but it won't recognize any directories. What am I doing wrong?
Try directory names with 8 or less characters.
1+1=10
Well, the folder I made is called "oldgames", so it should work. A directory is just a folder, right?
You are right.
What mounting commands did you use?
Try something like
Z:\>mount c c:\oldgames
Z:\>c:
C:\>
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
wrote:You are right. […]
You are right.
Try something like
Z:\>c:
C:\>
That's what I'm doing, except it never gets past the "mount c c:\oldgames" part. It always tells me that it doesn't exist, when I have it sitting on my desktop.
Where is "oldgames" on your computer?
Does it have to be in a certain place? It's just on my desktop.
yeah that is not the right place.
Water flows down the stream
And the right place would be?
the location you type at
mount c location
(so that would be
go to
drive C (harddisk C)
and make a new folder there
wrote:the location you type at mount c location […]
mount c location(so that would be
go to
Umm... How do I get there? I'm really bad with computers >___>
My Computer -> Local Disk (C:)
wrote:Does it have to be in a certain place? It's just on my desktop.
mount C "C:\Documents and Settings\Kanto\Desktop\oldgames"
(adjust for your Windows user name, and whatever "Desktop" is in your own Windows language)
Edit: Changed "My Documents" to "Desktop"
_________________
wrote:wrote:Does it have to be in a certain place? It's just on my desktop.
mount C "C:\Documents and Settings\Kanto\My Documents\oldgames"
(adjust for your Windows user name, and whatever "My Documents" is in your own Windows language)
No no, his desktop, not his documents folder. So replace 'My Documents' with 'Desktop'.
JAL
to be more specific...
mount C "C:\Documents and Settings\Kanto\desktop\oldgames"
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
oh and please. Consider using a frontend.
Even in a frontend he'd still have to understand file structure....right? Man I fear for the day when an MS OS has the filesystem even more obscured by useless BS.
Are you saying that /home/Kanto/oldgames is so much better than C:\Documents and Settings\Kanto\Desktop\oldgames?
lawl i prefered where the desktop was on win9x then how it is under winXP...... in win9x it was c:\windows\desktop\ where as in winXP its C:\Documents and Settings\%username%\Desktop\
my website
Why don't you just create a oldgames folder at the root level of C: drive?
Intel i7 5960X
8 GB DDR4 (2100)
