Reply 20 of 25, by havli
- Oldbie
Are you sure? There are 4 memory chips, 8MB each:
https://www.digchip.com/datasheets/parts/data … Y57V653220B.php
Hello
(my first post on Vogons)
I recently found a nearly identical 16Mb Geforce 256.
- Same brand (Guillemot)
- Same PCB layout, with no memory chips on the back.
I got the card a few weeks ago, but i just built the system needed to test it.
My card works, but it seems that the "blue" color is missing. Probably due to a bad/cracked solder joint.
Aside from the missing color, everything seems to work. I've tested WinXP up to 1920*1200 and ran UnrealTournament (UT99) in D3D Mode (XP default drivers).
After some online research, i found some mentions of a 3D Prophet SE 16MB :
I bought it from a local ad website. The previous owner listed it without any details ("3D Prophet" name + photo), so he had no details about the card either. I found the card by luck, recognizing the PCB layout on the picture.
Here are my captures / files.
This card looks like a lower cost version / entry level / OEM. With half of ram and underclocked components.
GPU@110Mhz and memory@143Mhz (instead of 120 and 166 for standard cards)
I also have a GPU Bios dump, but not sure if i can share it (copyright ?) or even how to preserve it ? (archive.org ?)
Edit : The bios is exactly the same as the one provided by the HansZ in this thread.
acl@laptop:~/Downloads/PIII-370$ md5sum NV10*05155874be24a26cb0f19d925a32725d NV10.bin05155874be24a26cb0f19d925a32725d NV10.rom
My test config :
As an extra question. My card obviously have a color problem. I strongly suspect a bad solder joint. No external damage. No PCB scratch.
I'm thinking about trying the oven trick (aka GPU baking). Do you have any advice about it ? (or about not to do it ?).
Thank you very much.
Edit : added cpu/mem freq.
Edit 2 : added bios md5 checksum
I would try tracing the blue pin on the VGA connector back to its source using a multimeter or preferably a scope . There may be a bad solder or a ripped passive component along the signal path .
Happy ending update
I made 2 other reflow attemps, this time soaking the chips pins with soldering flux.
And it's working perfectly now ! No artifacts. No missing colors.
So it took 4 oven baking to work again... and i think that it's 100% luck.
First at 180C° 11min, Second 200C° 12min, (Waiting 6+ month in a box) Third 190C° 11min with Flux, Fourth 200C° 11min with Flux.
This allowed me to test something i wanted to do for quite a long time.
Does Half-Life 2 can run on a 16Mb GeForce SDR.... and yes, it runs (So does Doom 3). But obviously with the lowest possible settings and DX7 mode.
In the same cooking batch, my Radeon X1950XTX also came back from the grave. So really good day.
(two other cards are still dead, Ti4600 and the HD 3870X2)
Edit : I also found more online reference to this card. Including benchmarks and retail prices.
https://www.tomshardware.fr/comparatif-de-gef … oire-graphique/ (in French, sorry)
This tends to prove that it's not an OEM only card. And the article also mentions A 32Mb GeForce256 LE. So more like a normal 256 but with slightly lower clock speeds.
To my surprise, there were also SGRAM (both SDR and DDR) versions.
I'm really tempted to update the Wikipedia article about GF256 as it does not mention these entry level versions. Only 32Mb SDR and 32/64 DDR versions...
Please do update the wiki!
A little late to the party, but I wanted to add some extra information.
I have the 3D Prophet SE 32MB. It runs as 110/143. I was attempting to flash a different BIOS on it and hosed the card - I think in the end it was the version of NVFlash I was using, as I used the BIOS in this thread and an older version of NVFlash and it came back to life (so thank you!).
But my card is the 32MB version and this BIOS was from the 16MB version. It still worked perfectly and detected 32MB correctly.
Using PowerStrip I then overclocked the card and found 125/175 ran nicely (130 and 180 ran independently but when put together it struggled, so dialed them both back).
I then modified the BIOS using NVIDIA BIOS Editor (also called X-BIOS), flashed it to the card and now it's set at these frequencies permanently, and I updated the BIOS string to show it's an "OC" BIOS.
I won't add the file here, as it's easily done yourself using the tools I've mentioned.
