Reply 17420 of 30901, by Namrok
So I beat StarCraft on my Budget '99 Retro PC. Installed off the original CD I bought 22 years ago in April 1998.
Victory Screen
The attachment 20201206_StarCraft.jpg is no longer available
I've beat a couple games on this build. Some I'd beaten before, some that were games I'd overlooked at the time. One thing that is constantly blowing my mind is that I totally forgot in 1998, when I was 14 years old, I almost always beat games with cheat codes. Especially strategy games. Playing them without now makes me realize how much I was missing.
Not sure what my next main focus will be. Been slowly playing through Unreal, and dabbling in Syndicate as well.
Win95/DOS 7.1 - P233 MMX (@2.5 x 100 FSB), Diamond Viper V330 AGP, SB16 CT2800
Win98 - K6-2+ 500, GF2 MX, SB AWE 64 CT4500, SBLive CT4780
Win98 - Pentium III 1000, GF2 GTS, SBLive CT4760
WinXP - Athlon 64 3200+, GF 7800 GS, Audigy 2 ZS
Reply 17421 of 30901, by Brutek
Hey Guys
found an old DFI Board at my attic.
Nice Color and true cool PCB Design for 2007 😀
Reply 17422 of 30901, by chrismeyer6
That's a nice board. I've always liked the DFI lanparty boards.
Reply 17423 of 30901, by Spitz
After fixing 3 laptops had to tidy up little bit to do some tests (benchmarks!) and post it later on 😉
Siemens 486 (PCD-4ND)
Toshiba 486 (t4850ct)
Toshiba P120 (700CT)
2nd Toshiba P120 (Tecra 510CDT)
Toshiba P133 (430CDT)
Toshiba P166 MMX (300CDT)
Well... I miss 80/90s ... End of story
Reply 17424 of 30901, by Caluser2000
Dragged 3 dot matrix from out of the ceiling that have been stored there for over 25 years. A Super 5 24pin line feed printer, Panasonic KX-1191 and Pansonic kx-p-1180. I'll make a good printer out of the Panasonic ones as internally they share the same component using the KX-1191 body as that has not yellowed like the KX-P-1180. Shouldn't take long.
I replaced DR Dos 6.0 on my Redstone Computers XT Turbo system with IBM Dos 5.02. IBMs first version of Dos for consumer use on non IBM systems. It seems to run a faster than DR Dos 6.0 when executing programs. Also fitted the blacked HDD floppies in it. It looks rather smart.
Reply 17425 of 30901, by RetroLizard
Are Biostar 486 boards any good, or should I avoid them?
Reply 17426 of 30901, by chrismeyer6
I can't speak to their 486 boards but I've never had any issues with BioStar motherboards in general.
Reply 17427 of 30901, by Mister Xiado
Ordered an Atari BASIC cartridge to troubleshoot the ROM BASIC issues in my Atari XE GS. I still haven't ordered (physically) smaller capacitors for my Gigabyte P4 board. Motivation for this stuff is in critically short supply.
Reply 17428 of 30901, by Horun
chrismeyer6 wrote on 2020-12-07, 22:25:
Their 486 VLB boards are built well, have a few and they are as good as an Asus, DFI, Giga or FIC of the same period imho
Reply 17429 of 30901, by Horun
Got a new TL866ii plus BIOS programmer and have been playing with it. Also made a pdf of a manual for a old PcChip motherboard, going to make another after I scan/photo the pages of the Opti 495 SX cache manual (Artek board).
And going to drink a few American beers from a company opened in 1852 here, if that is not vintage then what is 😀
Reply 17430 of 30901, by RetroLizard
Is this a good board?
Or this?
Reply 17431 of 30901, by ragefury32
Spent the weekend trying to get BeOS installed on my single-spindle Thinkpad 240. The T21 is still down (somewhat) due to the blink-of-death issue, and it doesn’t really have a caddy that can be used for SD-to-IDE adapters. What to do? The Compaq Evo N600c to the rescue. It’s a Tualatin P3m laptop, one of the last machines with both AC97+Legacy SB Pro hardware support (albeit with software wagetable FM synth).
It also has a HDD mounting rail that works well with SD2IDE setups - this is something often overlooked when working with 2-spindle vintage laptops.
Rail in...
MicroSD is great for testing like this. It’s (relatively) cheap and easy to work with.
The attachment E924CA56-B893-4D63-BCE9-1656284EFEEE.jpeg is no longer available
Rail out...
Although for heavy write situations this really need to be swapped out with an mSATA SSD and an adapter.
The attachment F836D00D-61F6-420C-8BAE-533C11D58FCA.jpeg is no longer available
Was able to get the BeOS R5 Installer image working - too bad not much drivers are available.
The attachment 714C6399-CB20-4B9B-AAF0-EEAF2CD1B82C.jpeg is no longer available
What about Haiku?
The attachment D9D2F1F2-5B79-4206-A37C-5B9B4AC21BEA.jpeg is no longer available
For some reason Haiku refused to boot up on the Evo n600c (freezing up on GPU init) but running the SD card as the virtual drive in VMWare player seemed to have worked. Not that it mattered that much, mind you. Haiku doesn’t work well on vintage hardware like this - on Beta1 r2 it’s missing drivers for Pre-AC97 audio, PS/2 trackpoint support is DOA, and apps like NetPositive requires SSE2 (which implies at least a P4/Pentium-M). It worked “okay” on the Tp240, but not enough for me to actually want to retain it.
Had to swap the DVD Reader/CD writer on the Evo to another unit that burns DVDs - not that I need the DVD burning capability. Actually, I was more miffed that the default drive does not read the DVD-Rs I burn. I swear, someone needs to make a JAE50 compatible optical drive emulator or something.
Oh well, swapping out the original in its caddy isn’t difficult. Just not that great for the machine cosmetically speaking. And at the end, not really needed.
The attachment 6073BE60-3F39-4C70-AAF7-38A3EEE1FFBF.jpeg is no longer available
Reply 17432 of 30901, by RandomStranger
I was just scrapping an older budget PC case for not particularly valuable, but convenient parts to have, like the front panel, buttons 5.25-3.5" bay converter when I thought, I always wanted a test bench, but I think 30$ for a piece of uATX sized plexi board and twice for an aluminium one with 6 motherboard stand-offs are shamelessly overpriced so I drilled out the full ATX sized motherboard tray.
Reply 17433 of 30901, by HanJammer
Built MCE2VGA, which required me to solder this SRAM IC, I think I never soldered anything this small so it was 'first time' for me, but I think it came out nicely...
Now I need to find somebody to program Altera FPGA for me as the cheap clone of USB Blaster causes bluescreens in my system (or maybe there's some solution to this problem?).
Also built some Atari 8-bit (XEGS/65XE/800XL) carts which use Flash ICs to store software, designed (some time ago) and printed enclosures as well...
Reply 17434 of 30901, by Caluser2000
Swapped the black front facia of an unreliable Sony 3.5" floppy drive and fitted it to a reliable TEAC 3.5" floppy drive. A bit of filing was required but I got there in the end.
Reply 17435 of 30901, by PTherapist
Did some slight modifications to a Commodore Plus/4 today. I was missing the Commodore key on the keyboard, plus the key plunger was damaged and spare parts for the Plus/4 are a little harder to get hold of.
So I bought a replacement key from a C64 keyboard from eBay. Of course the keys differ in fitting & size on the Plus/4, so some modding was required to make it fit -
I got out the hand saw and cut the key down to the correct size, then sanded the bottom to make it smooth & level.
I cut and mashed up the underside of the key, to remove the C64 fitting and then I cut up a small plastic tube and super glued it in place (tube is a little longer than normal Plus/4 fitting, this was because I intended to retain the broken plunger, don't want to be opening this up again to replace it). Then I found a spare spring and cut that down to size to fit the Plus/4 keyboard.
It may not be the prettiest looking, but it's a close enough fit for now and most importantly it works and fills a hole on the keyboard!
I'm still keeping an eye out for a replacement keyboard though, so I probably won't bother to try and retrobright this one.
Reply 17436 of 30901, by Caluser2000
PTherapist wrote on 2020-12-09, 16:38:
Did some slight modifications to a Commodore Plus/4 today. I was missing the Commodore key on the keyboard, plus the key plunge […]
That's the type of repair I like. Thinking outside the box...
Reply 17437 of 30901, by Dmetsys
Rebuilt the Tiger GT200 K6-2 desktop yesterday. Sure enough, the M577 that came with it shit the bed. No beeps, no signs of life. Replaced the M577 with my P5A-B, and now it runs like a treat. Just have to find ways to tidy up the cabling mess that comes with these older Baby-AT based systems.
NF7-S 2.0 | 2500+ @ 3200+ | 9700 Pro | Audigy2 ZS
CUV4X 1.03 | PIII-933 | MX400 | Live! Value 4670
P5A-B | K6-2 450 | TNT2 | AWE64 Value
4DPS | Am5x86-P75 | S3 Vision864 | SB16 CT2290
Reply 17438 of 30901, by Brutek
chrismeyer6 wrote on 2020-12-07, 18:38:
Yeah, most have reset + power Button and also debug LED.
Standard parts for good mainboards.
Reply 17439 of 30901, by Caluser2000
Purchased a can of beige matching touch up paint to refresh two 486 cases with surface rust. While I was in town I visited Cash Convertors. Got a set of speakers with AV connections and a HP 19" model L1910 lcd 4:3 monitor for the handsome sum of $nz14. The monitor is fine with no dead pixels.
