Reply 37240 of 52983, by Wolfus
Too bad it is not revision 2.00. It supports K6-2 CPUs. It wasn't easy to find out what revision it is (1.20 - I hope). It is not written anywhere on the board and every revision has different voltage settings!
Reply 37242 of 52983, by andrea
Wolfus wrote on 2020-12-13, 11:00:
It may not be in the manual, but the VRM controller seems capable of providing K6-2 voltages: https://www.onsemi.com/pub/Collateral/CS5151-D.PDF .
The truth table is on page 3.
Reply 37243 of 52983, by Horun
andrea wrote on 2020-12-13, 19:04:
Nice ! And it appears to have 4 sets of jumpers near that CS5151.
I found the archive link that says the "RB" is a v1.10, 1.20 or 2.00. Your board has the "RB" on bottom left of the picture, not "RA" so def not a V1.00.
Reply 37244 of 52983, by Wolfus
Horun wrote on 2020-12-13, 20:34:
2.00 has Award BIOS (earlier versions have AMI) so I have 1.1 or 1.2. This two versions have (according to manual) different settings for voltages and mine was set (got it with P200MMX installed) just like 1.2 should be.
Reply 37245 of 52983, by sf78
196.37 KiB
A diagnostic card. I'll try it later to see if it works. Seems to have more options and info than most Chinese cards. There was a thread for this here on Vogons, but sadly now manual. It seems a pretty straight forward thing though, even if the extra BIOS chips were not included.
Reply 37246 of 52983, by Nexxen
sf78 wrote on 2020-12-14, 12:42:
Far from the chinese counterparts 😀
Very interested in this card, can't wait to read if works and what it does - so much stuff on it......
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 37247 of 52983, by Xicor
Arrived today my favorite motherboard of all time the EVGA 790i Ultra SLI :
1.69 MiB
Also from the same seller a second Nvidia 7950GX2:
1.8 MiB
Had some trouble booting the 790i, but finally managed to post and boot. Guess that I will have to test this MB thoroughly.
Reply 37248 of 52983, by sf78
Nexxen wrote on 2020-12-14, 15:51:
I also have a vague feeling it's from the USA. I tried it on a known dead board and it surely gave zero output as it couldn't even start the POST procedures (power failure on the board).
Reply 37249 of 52983, by Predator99
Yes, that was me 😉
Re: ULTRA-X Professional Hardware Diagnostics P.H.D.16 - Made in U.S.A
Also have the manual, but too many pages to scan...
Reply 37252 of 52983, by Big Pink
When you want a house-warming P4, want to run 64-bit, but only have socket 478...
104.72 KiB
Intel Pentium 4 HT 3.2E SL7QB
Took a gamble on the eBay listing - the seller's photo was atrocious and the price too cheap considering its rarity. I was fully prepared for it to be a misread sSpec number. I'll stick it in my ASRock P4i945GC at some point.
I thought IBM was born with the world
Reply 37253 of 52983, by davebirl
Hi there
I just got myself a Tiny Pc with the MSI MS-5158 board. Have you any of the drivers for the video card, sound card and system board you could share with me? Either for Windows 95 or 98?
Many thanks
Dave
dionb wrote on 2019-04-18, 23:10:
Canopus is Japanese high-end stuff. Rare in the day as you paid through the teeth for the privilege. That hasn't changed ;) […]
Canopus is Japanese high-end stuff. Rare in the day as you paid through the teeth for the privilege. That hasn't changed 😉
Postman came here today too. Unfortunately nowhere near as spectacular as Batyra's (drooling for that I-RAM), but nice enough for me to be happy:
PQI 128MB 44p IDE disk-on-module (which will hopefully work in my 486SLC low-profile build)
MSI MS-5158 TX5 ATX motherboard with i430TX chipset and lots of nice ISA slots.
and of course the Yamaha MU50-XG. Not an MU80, but close enough. So now I have XG as well as GS. Maybe now I'll stop buying this stuff (and pigs can fly 😜 )
Reply 37254 of 52983, by debs3759
Big Pink wrote on 2020-12-14, 22:07:
That's a good combo. SL7Q8 @ 3.4 also has EM64T support, but I've never seen that one for sale..
Reply 37255 of 52983, by chrismeyer6
Nice find! That's the perfect cpu to have now that where coming into winter. Over the summer I was a few hours late to get one of those locally for 25 bucks.
Reply 37257 of 52983, by dionb
davebirl wrote on 2020-12-14, 22:08:
Hi there […]
Hi there
Many thanks
Dave
Hi Dave,
I just have the MS-5158 motherboard an have no idea which other components it is paired with in your TinyPC system. The motherboard itself doesn't need any drivers in Win98SE, it's supported natively. Not sure about Win95 - you might need Intel IDE drivers there for optimal performance, although it will certainly function out of the box.
Reply 37258 of 52983, by Wolfus
brownk wrote on 2020-12-14, 22:40:
Wolfus wrote on 2020-12-12, 23:47:
When I saw this board, I could not resist.
Do you mind if I ask what mobo it is? I cannot seem to find a 430TX board with the layout of yours.
Of course I don't. It's DTK PAM-0073i.
