Reply 37260 of 52808, by mastergamma12
Xicor wrote on 2020-12-14, 17:36:
Arrived today my favorite motherboard of all time the EVGA 790i Ultra SLI : […]
file.php?id=98190&mode=view
Nice, I was using the EVGA FTW version of that before I swapped it out with my X58 Lanparty.
The Tuala-Bus (My 9x/Dos Rig) (Pentium III-S 1.4ghz, AWE64G+Audigy 2 ZS, Voodoo5 5500, Chieftec Dragon Rambus)
The Final Lan Party (My Windows Xp/7 rig) (Core i7 980x, GTX 480,DFI Lanparty UT X58-T3eH8,)
Re: Post your 'current' PC
Reply 37261 of 52808, by sf78
Predator99 wrote on 2020-12-14, 19:54:
POST codes are not generated by the card but by the system BIOS 😉
I'll refrase: The output info seems to be pretty much as in any other diagnostic card, though this only has two 7 segment displays, but the other leds are identical to most cards.
Reply 37262 of 52808, by Skanque
New arrivals for the collection:
ATI Xpert 128 - Rage 128 GL
ASUS AGP-7700 TI Deluxe - Geforce 2 TI
ASUS AGP-V264GT3 - ATI 3D RAGE PRO AGP 2X
ASUS V8460 Ultra - Geforce 4600 Ultra
Pretty glad to add these to the collection, still trying to locate some specific ASUS boxes, but hopefully they will show someday.
Have a nice day
Reply 37263 of 52808, by pete8475
This might not be "retro" exactly but I just picked up an EVGA GTX770 for $60 from a guy on Kijiji!
The fan is a bit dirty, but it works nicely.
    195 KiB
    204.48 KiB
Reply 37264 of 52808, by henk717
Managed to finally find a ESS-Solo1 in my region for a great price (Or at all given they never popped up in my searches before) , last year i went with the YMF744 instead. I absolutely love the ymf! Its such a great card. But pure dos gaming has been really hit and miss for me with its dos extender requirement on my 2005 era VIA Motherboard.
With a bit of luck the cards will work side by side in my build so i can wire the ESS to the Yamaha line in, that way i could load in the ESS driver when i need it and otherwise use the YMF. It would give me the best of both worlds since the Yamaha to me is the much better 98 card, but the ESS is going to allow me to properly play Jazz Jackrabbit and Turrican 2 if it all works out.
Reply 37266 of 52808, by sf78
Back to recycling again for a 12€ lot. Any thoughts on the quality of the Seventeam PSU?
190.97 KiB
285.92 KiB
170.91 KiB
Reply 37267 of 52808, by PD2JK
About that Seventeam psu, the S looks like Seasonic. Could be a sub brand, but unlikely.
Reply 37268 of 52808, by RandomStranger
Not really bought, a co-worker dumped his old socket 939 board on me GA-K8N51GMF-9-RH including a single core Athlon and 3GB RAM.
Also the gatekeeper decided he has no use for his (not so) old (for a) s775 board with a Core2Duo E8200 and 4GB RAM and original driver CD.
And both with the IO shield.
Neither of them seem really remarkable, but the Asrock is a VERY compact little board which can make a very compact XP box as for the Gigabyte, I've no experience with anything AMD between the K5 and Phenom 2 and having a short-lived socket is at least instead of something more dime-a-dozen is at least something to be excited about. Though the top dual core CPUs however seem to be somewhat rare.
Reply 37269 of 52808, by Skanque
blurks wrote on 2020-12-16, 07:15:
Nice finds @skanque. They all look to be in pristine condition too.
I just recently bought an ATI Mach64 VLB including the memory upgrade module (resulting in 4 MB total).
Thanks! Yes they are in excellent condition, I am very happy and surprised to find the AGP-V264GT3, since I have not seen any pictures of those boxes before.
You are also finding nice boxes, I saw your recent Creative finds.
Reply 37270 of 52808, by SVD
Cubix Server Processor Card A4010 with AMD 586 133ADZ incoming in the mail 😀
    61.93 KiB
Reply 37272 of 52808, by Robin4
sf78 wrote on 2020-12-16, 14:42:
Back to recycling again for a 12€ lot. Any thoughts on the quality of the Seventeam PSU? […]
If its a Hi-pot then is decent. If not then its not great..
Reply 37273 of 52808, by gex85
Today I found and bought a Slot 1 to S370 adapter with adjustable voltage that will go as low as 1.4V, the AOpen FC-PGA.
154.18 KiB
FC-PGA
(Photo shamelessly taken from here)
I will use it with a 440BX board and a Tualatin CPU, but haven't decided yet whether I'll just mod it or shell out some more Euros for a PCB solder-on adapter from "the Korean guy" on eBay. I have done the mod successfully in the past, but I like how clean the PCB solution is. But given the fact that I already kind of overpaid for the slot adapter, I might just do the mod myself...
My retro computers
Reply 37274 of 52808, by bjwil1991
Got these beauties today:
Super P54VL-PCI
EXP 8x CD-ROM multimedia PCMCIA drive with the card, drivers, and manual.
Gallery: http://imgur.com/a/ZXacreB
Reply 37275 of 52808, by LewisRaz
SW60XG midi board arrived today. Had some faffing around to get it to work but am very happy now!
Also the box it was posted in was... Interesting.
    117.9 KiB
    333.53 KiB
My retro pc youtube channel
Twitter
Reply 37276 of 52808, by Warlord
gex85 wrote on 2020-12-17, 13:12:
Today I found and bought a Slot 1 to S370 adapter with adjustable voltage that will go as low as 1.4V, the AOpen FC-PGA. AOpen_F […]
It will work but you need one of those lin lins or one of those ebay Tualatins with the adapter. Pretty nice slocket though, with a VRM.
Reply 37277 of 52808, by darry
Warlord wrote on 2020-12-18, 01:10:
Are you sure it has a VRM ? I thought the only slotket with a VRM was the PowerLeap one . AFAIK, all the other slotkets only allow overriding the CPU VID presented to the motherboard's VRM circuit .
Reply 37278 of 52808, by Warlord
darry wrote on 2020-12-18, 02:20:
Does an ABIT slotket III have a VRM
This says it have same chip as on powerleaps https://translate.google.com/translate?sl=aut … s/tbx/tbx_2.htm
Reply 37279 of 52808, by darry
Warlord wrote on 2020-12-18, 02:56:
AFAIK, the ABIT slotket III does not have a VRM . The chip you are referring to is a TVC16222 or TVC16222A , which, as far as I know, is used for I/O voltage conversion . Again, AFAIK, the supply voltage for the CPU is fed directly from the motherboard's VRM circuit on all slotket variants I know of, except the Powerleap PL-IP3/T, which has it's own VRM circuit (which is fed through a direct connection from the PSU) .
I am not an expert at this, so If somebody here knows more about this and/or if I got something wrong, please feel free to supplement/correct me .
