Reply 200 of 304, by slivercr
- Member
So, custom cooling solution for the OR840.
I've been saying I'd do something about it for a couple of years now, most likely design and print something. Well, today I finally started. The first step was modeling some Slot 1 CPU brackets, which were notoriously absent from thingiverse 🤷🏾
You should be able to find some now 😉
Please note that while all Slot1 CPUs will fit, only SECC CPUs (original Pentium2 cartridges, some heatsinks like mine) will be properly supported and locked. They are modeled after IBM brackets, which I will completely reproduce later on if no one remixes these.
Outrigger: an ongoing adventure with the OR840
QuForce FX 5800: turn your Quadro into a GeForce
