80486 BIOS image collection
Reply 60 of 187, by Horun
Manufacture: FIC ELI6-II
Chipset: VIA 82C486A
BIOS String: 03/14/95-VT82C486A-214L2000-00
BIOS label: ELI6-U555
BIOS Version: Award U573 3/14/95
From Unisys ELI 46665 Desktop
Reply 61 of 187, by Deunan
Manufacturer: ??? (possibly SOYO)
Chipset: UM8498F + UM8496F
BIOS string: 12/08/94-UMC-498GP-2C4X6S21-00
BIOS label: BIOS ISA 486
BIOS version: Award Modular BIOS v4.50G
Sorry for ebay watermarked photo, I'm unable to make any better one at the moment so the seller's photo will have to do.
This seems to be a cheap mobo with minimal BIOS options. It's in a pretty sorry state and I only bought it for parts, but decided to try and fix it to see (with a POST card) if the CPU actually works.
I got it to boot though so with keyboard working I run some tests - here's quick notes before it gets disassembled:
- BIOS has HDD detection, seems to support HDDs >504MB by allowing head count to be greater than 16
- BIOS has RAM waitstate and ISA clock divider selection
- no VLB, only 16-bit ISA slots
- no external cache
- internal cache seems to cover only the first 4MBs of RAM (that's what CACHECHK reports)
- 25/33/40 MHz CPU clock options
- CPU seems to work well at 40MHz with zero-WS RAM
- mobo runs fine on a single 72-pin 16MB FPM stick
- even with just the on-chip cache, the U5 outperforms a typical 486 by about 20%
At 33MHz cache is 67.4 MB/s and RAM 30.6 MB/s (0WS), and at 40MHz it goes up to 81.0 MB/s / 36.7 MB/s
Reply 62 of 187, by Deksor
Manufacture: Gemlight GMB-486UNP v2.1
Chipset: Unichip U4800-VLX
BIOS String: 40-0405-428036-00101111-080893-U4800-VLX-H
The attachment GMB-486UNP v2.1 front.jpg is no longer available
The attachment GMB-486UNP v2.1 back.jpg is no longer available
The attachment BIOS is no longer available
Reply 63 of 187, by Ph@nt0m-X
Manufacture: Soyo 025K2
Chipset: SiS 85C471
BIOS: Rev G2 - 09/26/94
The attachment sy-25k2.jpg is no longer available
The attachment sy-25k2.zip is no longer available
Reply 65 of 187, by computerguy08
Manufacturer: JETWAY J-403TG GREEN VLB ver 2.0
Chipset: OPTi 82C895
POST string: 07/21/94-OPTI-802G-2C4UKJ11-00
Date: 21.07.1994
The attachment J-403TG.jpg is no longer available
Reply 66 of 187, by theoryboy
Manufacturer: JETWAY J-403TG VLB Rev D
POST string: 40-P301-001276-00101110-121593-OPTi895-H
Date: 6/30/1994
The attachment J-403TGD.jpg is no longer available
The attachment mrbiospopti.jpg is no longer available
The attachment amibiospopti.jpg is no longer available
Both Bios:
The attachment J403TGRevD.zip is no longer available
Reply 67 of 187, by Horun
Manufacture: Mitac IH4077C
Chipset: UMC UM82C491F + UM82c493F
BIOS String: 04/13/94-UMC-491-2C4X2m31-00
UMC491F 80486 BIOS...1.01.00 (3371-3372)
BIOS label: IH4077CN BIOS R1.01.00
BIOS Version: Award 4.50G 04/13/94
some Vogons posts about this board: search.php?keywords=IH4077C
Reply 68 of 187, by AskNotes
Manufacture: Chaintech 4SPI
Chipset: SiS 85C496/7
BIOS String: 02/16/95-SiS-496-497/A/B-2A4IBC31-B2
BIOS Version: Award v4.50G
From ZX Spectrum to IBM PS/2 30 and so on. http://asknotes.com/
Reply 69 of 187, by HanJammer
Motherboard: Abit AB-AV4 (aka VL-BUS 486)
Chipset: SiS 85C461
EPROM: ST M27C512
BIOS String: 40-01BB-001247-00101111-111192-SIS461
BIOS label: CACHE 486 SYSTEM BIOS
BIOS Version: AMI 11/11/92
TH99: http://www.uncreativelabs.de/th99/m/S-T/35065.htm
Reply 70 of 187, by Madao
Motherboard: TMC PAT48AV 1.4
Chipset : ALi M1429 A1
Bios: AMI Bios, version unknown.
The attachment IMG_20200928_164935.jpg is no longer available
The attachment PAT48AV_bios_27C512.zip is no longer available
#70
Motherboard: MBA-029 (vendor unkown)
Chipset: SIS 85C401 & 85C402
BIOS: AMI, unknown version
The attachment mba_29.jpg is no longer available
The attachment MBA-029_bios_27C512.zip is no longer available
Reply 71 of 187, by Predator99
Manufacturer:
Chipset:
BIOS:
The attachment 486_AA1177169.jpg is no longer available
The attachment 486-AA1177369.zip is no longer available
Reply 72 of 187, by fool
Manufacturer: ABIT
Motherboard: AB-AX4
Chipset: SIS 401/402
BIOS: AMIBIOS 06/06/92 (different than in #71)
edit: corrected numbering
Toshiba T8500 desktop
SAM/CS9233 Wavetable Synthesizer daughterboard
Coming: 40-pin 8MB SIMM kit, CS4232 ISA wavetable sound card
Reply 73 of 187, by Horun
Madao posted #69 and #70. Pred posted another #70 and fool posted #71, which should be #71 and #72.
#73
Motherboard: Addtech Research 4GLX3
AKA VisionEX 4GPV3
Manufacture: Addtech Research/CTL
Board Markings: 4GLX3, Green-B 4GPV3.1
Chipset: Contaq 82C596A
BIOS Strings: (AMIBIOS) 01/10/94 (C)1994 American Megatrends Inc.,
40-0101-006666-00101111-011094-CTQ-596A
KIM Computer by CTL Corporation
Model : [4GLX3] --- Made in U.S.A.
EPROM: ST M27C512
BIOS label: AMI BIOS 486DX 1992
BIOS Version: AMI 01/10/94
MH99:
https://arvutimuuseum.ee/th99/m/A-B/32055.htm
https://arvutimuuseum.ee/th99/m/U-Z/33399.htm
http://www.win3x.org/uh19/motherboard/show/321
Reply 74 of 187, by Horun
Motherboard: Amptron DX9200 AKA PcChips M915i
with Fake cache
Chipset: UMC UM8881F + UM8886BF
EPROM: AMD AM27C010
BIOS String: 41-p400-001437-00101111-101094-486AVIP-H
BIOS label: AMI 486DX ISA BIOS 1993
BIOS Version: AMI 10/10/1995: 11-08-1995
CRC 32bit Checksum: 82A4E810
Note: this Fake Cache bios is not same as the M915i BIOS 9151108s floating around.
http://www.win3x.org/uh19/motherboard/show/579
http://www.win3x.org/uh19/motherboard/show/5944
Included the 9151108s BIOS
Reply 75 of 187, by HanJammer
Motherboard: TMC PAT48PG4-V1.20
BIOS Version: Award 10/13/95
Chipset: OPTi 82C895+82C602
EPROM Label: 486 AWARD SOFTWARE 1984-1995
BIOS ID String: 10/13/95-OPTI-802G-2C4UKM21-00.00-00
Reply 76 of 187, by Darkscop
Motherboard: FIC 486-VC-HD
DOC: 11670
BIOS Version: AMI 05/05/1991
Chipset: VIA VT82C495 VT82C481
EPROM Label: 486EB
BIOS ID String: 40-04C1-ZZ1124-00101111-050591-ET/486H
Reply 77 of 187, by Windows9566
Motherboard: A-Trend ATC-1425B
BIOS Version: Award 4.51PG 04/18/96
Chipset: SiS 496/497
BIOS String: 04/18/96-SiS-496-497/A/B-2A4IBA2BC-00
The attachment s-l1600 (1).jpg is no longer available
The attachment atc1425bbios.jpg is no longer available
The attachment ATC1425B.7z is no longer available
R5 7600X, 32 GB RAM, RTX 3060 TI, Win11
P3 750, 384 MB RAM, Matrox G400, Sound Blaster 32, Win98
PMMX 166, 64 MB RAM, S3 Virge DX, Aztech AZT2316R, Win95
486DX2 66, 32 MB RAM, Cirrus Logic GD5430, Aztech AZT2316, DOS
Reply 78 of 187, by BurnedPinguin
Motherboard: PCI486 V1-HJ3
BIOS Version: American Megatrends AMI WINBIOS AB1301020 1993
BIOS String: 41-C101-428027-00101111-101094-ALI87/89-U
Chipset: ALi M1489
Reply 79 of 187, by Distortions
AMIBIOS 486-SX/DX, 1992
Chipset OPTI
Board Mark: UNIC2 94V-0 9326
06/06/92
American Megatends
X0-0100-001378-00101111-060692-495SX_A
