First post, by athlon-power
I have an ASUS A7S333 motherboard that seems to work great so far (I have two socket 462 processors for it), and am planning to use it in a system to properly play some Win9x games (Half-Life, Quake III, Unreal, etc.) instead of using time-accurate hardware and suffering with the terrible performance that unavoidably comes with such hardware configurations- I've been working on a time-accurate Slot 1 build to run these games well for years.
Anyways, I have an Athlon XP 1800+ (Palomino) and an Athlon XP 2600+ (Thoroughbred, 266 MT/s). I'm wanting to put the 2600+ in there, but in order for it to get above 1800MHz (the 2600+ runs at 2133MHz), and to get the system to recognize the CPU properly, I have to flash a newer BIOS. Normally, motherboard manufacturers package the flashing tool in with their BIOS, but not in this case- instead, they left me to have to find it myself. Here are the links I've been using for both the BIOS and flashing tools:
BIOS: https://www.asus.com/supportonly/A7S333/HelpDesk_Download/
AWDFLASH: https://www.wimsbios.com/awardflasher.jsp
The issue here is that the latest version of AWDFLASH says that the BIOS images are the wrong kind- they're not. I have the SiS 795 chipset if there's a possibility of two of these kinds of motherboards existing, which I doubt, but it is possible. I have tried 8.99, which says it's incorrect, 8.65 says "please wait," but freezes on that, 8.30 says that the ROM on my motherboard isn't updated enough (???), and 8.00 freezes and says nothing. 7.xx and below seem to be a fair bit older than this motherboard, so I doubt the BIOS chip in use here is supported.
Any help is greatly appreciated, I've tried this using both the 2600+ and the 1800+.
Where am I?
Reply 1 of 3, by zyga64
You may try Uniflash http://www.win3x.org/win3board/viewtopic.php? … 455&language=en
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-2@400 /64M /MGA-2064W+3dfx /YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 2 of 3, by cyclone3d
If I remember correctly, some of the older ASUS boards had a special flash utility provided by ASUS.
Edit: here it is:
The attachment aflash221.zip is no longer available
It is not in the BIOS download section on the ASUS site.. it is in their normal download section after you select DOS as the OS:
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 3, by athlon-power
The
cyclone3d wrote on 2020-12-19, 00:35:
If I remember correctly, some of the older ASUS boards had a special flash utility provided by ASUS. […]
Edit: here it is:
Thank you, that worked perfectly. For some reason it didn't show that program when I selected the DOS tab, so that part may have been a bug on my end instead of ASUS's.
zyga64 wrote on 2020-12-18, 21:23:
Also thank you for providing that, I'll likely end up using it in the future.
The CPU I'm using has several chips on the top and bottom edges of the die, but seems to work perfectly fine. I hate that it's somehow possible but at the same time I'm kind of glad CPU's are either dead or they're not- there's no real in-between. I at least have the 1800+ in case something happens.
Where am I?
