Sad Socket 4 motherboard
First post, by Per
In hinsight, I should have removed that battery years ago. On the other hand after a vinegar wash, solder mask held up allright, damages doesn't seem too bad, and looks quite fixable if I can get hold of the resistance values of the missing resistors.
If anyone has a similar board, I would be really happy if you could check up the resistor-values of R40-R46 for me.
A bit more info on the board, it's from an AT&T first generation Pentium (60MHz) machine, and seems like the board is named "PB5500C". It has an OPTi "Premium" 82C596/597 chipset.
Reply 1 of 9, by PD2JK
Are the contacts of those missing resistors 'too clean'? Could be that those weren't soldered in the first place.
Nice board, socket 4 boards are quite rare.
has all kinds of stuff
Reply 2 of 9, by Per
They were there, but the tin was crumbling. Really brittle stuff after corrosion. I didn't realize they were coming off untill most of them were gone.
Reply 3 of 9, by evasive
Can you post whatever comes after 411-6??4-????-???? please? I think this is a MiTAC board but it's possible it was never sold as retail, only inside a Compaq/HP machine possibly. For that I'd need the 411 <something> number.
Reply 4 of 9, by Per
it's just 411-6894-[]R[]. Nothing is written into the filled areas. The sticker in the middle says 17- 28746627.
Edit, back side PCB trace layer says 316-6894-00001 R01. Made in 46th week of 1994.
Reply 5 of 9, by Per
Update, found a few of the resistors in the waterlock of the sink. there's at least one 103 (10k), two 102 (1k) and one 330.
Reply 6 of 9, by PD2JK
Did you rinse it? 😁
Reply 7 of 9, by Per
Well, there was thick white battery goop all over the place between those two ISA slots. First priority was to get that nastiness off.
Reply 8 of 9, by quicknick
Strange to see such damage so remote from the battery. Should be much worse near it. Or maybe something else was spilled between those ISA slots...
Reply 9 of 9, by Per
quicknick wrote on 2020-12-27, 23:42:
It was an external 3.6v litium battery which was stored still connected, laying on top of the motherboard. I was not aware external batteries like that could leak through the plastic enclosure at the time it was put into storage.
