Reply 37360 of 52951, by appiah4
appiah4 wrote on 2020-12-24, 08:56:
Acquired a bit of stuff lately. First, the less important stuff: […]
Slotket-MSI-MS-6905.jpg Intel-Celeron-1300-B.jpg Creative-Sound-Blaster-16-Value-CT2770.jpg
Now, the more interesting merchandise. A boxed and allegedly NOS 486 motherboard popped up for around $15, so I jumped on it and grabbed it. It was untested in unknown condition so I gambled my chances.
AOpen-Vi9-Unboxing-01.jpg AOpen-Vi9-Unboxing-02.jpg AOpen-Vi9-Unboxing-03.jpg
Whoa, that's a 386/486 Hybris motherboard with VLB? An AOpen Vi9 apparently. Not sure whether it's a valuable piece or collectable, but it sure is interesting to me! No cache, but I have spare cache chips from other dead motherboards lying around if I ever want to use it.
Of course it came with obligatory barrel battery leakage..
..which looked pretty horrible, particularly on that sticker at the bottom - I thought the traces were already lifted and gone.. But it actually wasn't that difficult to mostly fix with vinegar, alcohol and some scrubbing with a flat head screwdriver.
And voila:
I haven't tested it for POST yet but all the traces have continuity. I will do a POST test later tonight.
Well, this board does not seem to POST at all. Nothing on the POST card either. I tried it with or without cache installed, no dice. I get power to the CPU, it gets a bit warm and that's about it - nothing else.. Sad 😒
Reply 37361 of 52951, by H3nrik V!
PC Hoarder Patrol wrote on 2020-12-25, 03:46:
"Hey, Santa's been at the E-waste again!" […]
A complete 370DER
Beautiful board! I love that the layout has the CPUs sitting next to each other, rather than the often used layout, where they're offset.
Is it Intel, VIA or ServerWorks chipset?
Reply 37362 of 52951, by PC Hoarder Patrol
H3nrik V! wrote on 2020-12-25, 08:38:
A complete 370DER
Serverworks™ Serverset III HE-SL
The socket layout might be a problem for larger (80mm) heatsink/fan combos as I don't think they'll fit side by side, though as it's a 1U/2U board that probably wasn't relevant.
Reply 37363 of 52951, by CMB75
Haven’t bought much tech lately... but I stumbled upon an ASUS XP55T2P4. Although I don’t really need another S7 I just couldn’t resist. Supposedly has a dead PS2 mouse port - so I’m going to have some fun tinkering
720.22 KiB
sellers pic
(sellers pic)
Reply 37364 of 52951, by Thermalwrong
bjwil1991 wrote on 2020-12-25, 01:14:
Bought the following: […]
HardMPU MPU-401 card
DPT PM2022 EISA SCSI card
2x LT1084CP VRMs for my Socket 5 board
Pack of 10 SOJ-40 LIF sockets for easier RAM replacement
Nice, that HardMPU is really excellent for DIY hardware, it's 'just worked' with everything I've thrown at it so far with my MT-100 and SB-155 (the less cool MT-32 and SC-55). You've got the proper one that ab0tj made so it should work really reliably 😀
This has been a really fun christmas, I got some laptops in; 3x Thinkpad 600 laptops (a 600, a 600E and a 600X) with various faults. Also a really cool 486 laptop with a DSTN screen. The hard drive was dead and the screen hinges were phyically destroyed (all the screw mounts cracked off so the screen flopped open & closed). That was fixed with some thermo plastic stuff to rebuild the screw mounts for the hinges. I was going to fix it more properly but this works surprisingly well, the hinges work again 😀
This PMD-5500 laptop is really cool since the screen can flip around like Creepingnet's NEC laptops, just without the touch screen. This is my favourite 486 laptop so far, no L2 cache, but it's got an Intel 486 DX4-100, an 11.3" DSTN screen that is in surprisingly workable condition and a soundcard with a Game/MIDI port. It's 60mm thick, one phat laptop!
The CMOS battery needed to be replaced, a VL2330, because the laptop wouldn't boot with a flat CMOS battery. The original battery wasn't holding its 3v charge anymore, but I'm super happy I had a replacement in the flat 😁
It's got a temperature controlled fan on the processor, so mostly it's nice and quiet 😀 And the guy that made the page for the PMD-5500 laptop was kind enough to scan the manual, which has solved a lot of mysteries.
Reply 37366 of 52951, by H3nrik V!
Bought a Matrox M3D yesterday. In working condition.
But now I just thought - are there drivers for XP so I can use it in my BP6 dual Mendocino build?
Reply 37367 of 52951, by gotohell
bofh.fromhell wrote on 2019-05-08, 21:57:
Snagged an ABIT KA7 for peanuts. Obviously the caps are all OK, as seen on the pic ;) Tho I'm fairly sure theres a few other iss […]
Obviously the caps are all OK, as seen on the pic 😉
Tho I'm fairly sure theres a few other issues with it, can you find them ? =)
Salute, do you have datasheet for this MOBO?
(on my 5v to GRND - 300Om / no 3.3v on mobo)
https://t.me/hwretard
Reply 37369 of 52951, by blurks
H3nrik V! wrote on 2020-12-28, 17:26:
I'm not aware of any XP driver available for the NEC PCX2. Keep in mind: it is a 1997 graphics accelerator chipset. Windows XP came out much later in 2001 when NEC, Videologic and Matrox supposedly didn't have any desire or interest in spending ressources for a new driver of an obsolete piece of hardware.
Reply 37370 of 52951, by canthearu
Hakeshu wrote on 2020-12-28, 22:08:
This beauty arrived today. Will make some tests on my Pentium 200 (atm with a Trident 3D 9750).
Have my fingers crossed for you. Some S3 Virge cards have OK display output, others are totally blurry and crap.
Reply 37371 of 52951, by Ozzuneoj
sf78 wrote on 2020-12-28, 14:11:
Last of the haul. Gonna take some time to go through this and post proper pictures.
I'm getting that itchy feeling looking at all that. Like I need to put out ads looking for old PC parts in the local classified ads again. Been a while since I had a haul like that to sort through... unless you count the huge pile of Apple II gear someone gave me recently. Somehow, it's just different with PC stuff because it's exciting to find something I know is rare or useful... with Apple stuff it's all totally unknown to me, so it was fun but was more of a learning experience than a treasure hunt. 😁
Reply 37372 of 52951, by Horun
CMB75 wrote on 2020-12-27, 19:53:
(sellers pic)
Nice ! The Asus P55TP series were all very good boards.
Ran into this looking around and am considering buying just because it is quite odd for a 486, sent seller some questions.
Anyone ever see a 486 board like this with onboard everything and still a regular AT style ?
    519.86 KiB
Reply 37373 of 52951, by Ozzuneoj
Wow, never seen anything like that. Looks like CL GD5428 graphics onboard, with room for memory expansion? I wonder if it's 1MB or 2MB max. And what's with the memory chips near the RAM slots? It looks like it says OB MEM ENABLE... OnBoard memory? As system RAM, or as an IDE cache? All very strange.
Biggest concern though: That battery. What a bad location. Battery corrosion is undesirable in the usual location near the keyboard port, but it tends to be much more sparsely populated with traces. Up near the CPU, jumpers and VLB slots you could have all sorts of odd problems. I'd definitely ask for some closeup pics of the front and back of that area.
Reply 37374 of 52951, by bjwil1991
TechMedia 486 motherboard. Looks like up to 2MB max for the video chip. There are TechMedia systems for sale as well, but I'd rather not post the link on here.
And why a Varta Nickel Leakium battery is beyond me.
Reply 37376 of 52951, by Spitz
blurks wrote on 2020-12-29, 00:33:
I don't recon using my M3D on XP last OS was WinMe.... I doubt there are any drv for XP
Well... I miss 80/90s ... End of story
Reply 37377 of 52951, by H3nrik V!
Spitz wrote on 2020-12-29, 08:22:
Oh well, better get into an XP/ME dual boot then 🤣 Seller had screen shots from device manager, and I actually first thought it was XP, but it's been a while, so I'm probably remembering wrong ..
Just need to see if I can find the screen savers originally on the Matrox M3D CDs .. Those were legendary 😀
Reply 37378 of 52951, by fool
Some of the better half. I really hope 8MB ATI Rage II works...and it does!
Toshiba T8500 desktop
SAM/CS9233 Wavetable Synthesizer daughterboard
Coming: 40-pin 8MB SIMM kit, CS4232 ISA wavetable sound card
Reply 37379 of 52951, by winuser_pl
I received "POST" card for both PCI and ISA interfaces. I hope it will help me to identify the problems with POSTing my Tyan Tiger S2466 dual athlon MP soon 😀
    1.26 MiB
PC1: Highscreen => FIC PA-2005, 64 MB EDO RAM, Pentium MMX 200, S3 Virge + Voodoo 2 8 MB
PC2: AOpen => GA-586SG, 512 MB SDRAM, AMD K6-2 400 MHz, Geforce 2 MX 400
