MT-32 wavetable daughterboard exist
First post, by Paar
Check this video: https://www.clous.cz/jamicon-spacestation-386/
The owner of the computer uses generic ISA card with a DIY waveblaster daughterboard which seeems to be fully compatible with MT-32 standard and sounds excellent. It's even compatible with Legend of Kyrandia 1, which needs intelligent MIDI mode. Would be nice to see what the board really looks like!
Reply 1 of 31, by gdjacobs
Kyrandia doesn't use much in the way of custom instruments. SoftMPU and a Roland compatible wavetable card with MT-32 emulation will sound decently close to the real thing. Not saying that's what's going on as I'm not as knowledgeable as Hierophant or NewRisingSun, but Kyrandia isn't the high bar that many other titles are.
I still like the PC in a keyboard thing, though.
Reply 2 of 31, by Thermalwrong
If you run his site through google translate, he's connecting an MT-32 & SC-55 off camera to the Aztech soundcard. I'm fairly certain, there isn't an MT-32 daughterboard just yet, until we have a Pi CM-4 and Munt performing that task 😉
Nice to see Clous mentioned on here 😀 His videos of old laptops and old PCs are pretty enjoyable and I think his site has the most info on old laptops currently on the active Internet.
Reply 3 of 31, by Paar
Well I'm sure he's not using real MT-32 or SC-55 module and it really is ISA card with a daughterboard only. He's showing the back of the computer and you can see it's directly connected to the speaker out jack of the card, there is no other connection.
But it is possible it's just some other General MIDI wavetable board using MT-32 emulation. Either way, it sounds great and even produces sound effects nicely.
Reply 4 of 31, by Srandista
Thermalwrong wrote on 2020-12-28, 01:51:
Trust me, Paar really doesn't need to use Google translate on that site 😉 Also, Clous wrote on that site, that you can connect MT-32 or SC-55 to sound card in that PC, not that he's connected those devices there.
Reply 5 of 31, by Salient
Paar wrote on 2020-12-27, 20:27:
... a DIY waveblaster daughterboard which seeems to be fully compatible with MT-32 ...
See: http://members.home.nl/c.kersten/
It says "And just today two more, very special new boards arrived from the same source: LAPC on a MIDI daughterboard! It must have been especially difficult sourcing those chips....
Haven't had time to test them yet, but I will do so very soon. I already put them on my flatbed scanner, so photos are coming too!"
Might as well be that board?
Reply 6 of 31, by Paar
Yeah, this could be the same thing. I know for sure it's just plain ISA sound card with MIDI daughterboard only but I have no idea how it looks like or how it works. I just know (thanks to the video) that compatibility is great and that it sounds excellent. Wish I knew more about this product!
Reply 7 of 31, by gdjacobs
Paar wrote on 2020-12-30, 19:06:
I'm suspecting it's SoftMPU with a Roland based, Crystal based, or similar daughter card (featuring an MT-32 mode).
Reply 8 of 31, by Paar
Well, I have checked again the video and he is using SoftMPU. Makes sense since Legend of Kyrandia doesn't work with UART mode. Nice to see it works great with 386 SX25. Is MT-32 emulation on GM cards capable of producing proper sound effects?
Reply 9 of 31, by gdjacobs
Paar wrote on 2020-12-30, 20:39:
Not completely, although it can be okay when titles stick to the default instruments.
Reply 10 of 31, by Srandista
gdjacobs wrote on 2020-12-31, 06:08:
Which is unfortunately (for this use case) quite uncommon.
Reply 11 of 31, by CHiLL72
Salient wrote on 2020-12-28, 17:13:
See: http://members.home.nl/c.kersten/ […]
It might be. I have two of these boards, which are slightly different from one another. Here are two (partially obscured) photos for you. These boards were created by a fellow VOGONS member.
The attachment LA32 - 1.jpg is no longer available
The attachment LA32 - 2.jpg is no longer available
Waveblaster MIDI boards: https://waveblaster.nl - online now!
Reply 12 of 31, by Paar
Those boards look awesome. Nice to see the real thing. Too bad it's partially obscured but I guess it's either to protect the design or to avoid possible legal issues. Thanks for the photos! I hope more of these beauties will get publicly available someday.
Could you be more specific how those boards work and how is the compatibility?
Reply 13 of 31, by gdjacobs
CHiLL72 wrote on 2021-01-03, 21:06:
It might be. I have two of these boards, which are slightly different from one another. Here are two (partially obscured) photos […]
What sorcery is this? Has someone been digging around the Roland graveyard in the dark of night to unleash this creature on us?
Reply 14 of 31, by Paar
I guess it's something similar to McCake but with FPGA and real chips. I have no idea how hard is to source those parts and hope no functional MT-32 has been hurt in the process! 😁
Reply 15 of 31, by root42
Howly cow. Thos LA32 Devboards look lovely! Amazing stuff! And yeah, I hope no MT32 had to be gutted for that! No functioning at least... I guess in the end an FPGA solution which doesn't need the LA32 IC would be best and give very good compatibility.
YouTube and Bonus
Reply 16 of 31, by keropi
noone in their right mind woult gut a mt-32 to make it a daughterboard, rest assured
the roland chips used in computer modules we love are not unique to them so chance are something "junk" and "unusable" was the donor. 😉
Reply 17 of 31, by root42
Yeah, they were used in keyboards as well I guess. However I also think it's not viable to build many of these, as donors are probably quite rare still.
YouTube and Bonus
Reply 18 of 31, by carlostex
I guess the DB can be only compatible with one of the devices, probably the CM-32L.
But probably with the MT-32 roms can be programmed instead.
Reply 19 of 31, by BloodyCactus
its funny to see those old intel embedded mcs-96 / 8095 cpus.
