First post, by garrisontrantow
In a skateboard, the skateboard trucks which have a shape like the T letter exert a significant contribution to the whole skateboard. In this post, we would like to illustrate some information related to skateboard trucks for you so that you can pick high-quality skateboard trucks effortlessly. By having good skateboard trucks, your experience of having a ride will be more and more amazing and fascinating. Let’s start the trip by exploring skateboard trucks with us right away.
Choose the right size
Choose a high skateboard truck if you want to drive about or ski transitions/mini ramps/bowls. Low trucks are best if you merely want to practice skating techniques or if you like to skate in streets or parks.
In addition, low skateboard trucks, standard skateboard trucks, and high skateboard trucks are the three types of trucks; however, most manufacturers only sell high and low skateboard trucks.
Trucks for different skateboard truck types
The first skateboard truck we would like to suggest to you is the Independent Skateboard Trucks. This is the skateboard truck which is regarded as one of the best skateboard trucks with excellent features. With reference to the price, you need 50 dollars more or less to pay for the item.
With aluminum hanger and baseplate, as well as a Chromoly steel axle, these trucks are tough and lightweight. Besides, you also receive the Supercrush cushions. The appropriate skateboard deck size which suits the Independent Skateboard Trucks is from 7.5 inches to 8 inches.
Next, it is the skateboard trucks which are exclusively for skaters who are looking for super light skateboard trucks. It is Havoc 5.0 Skateboard Trucks - a must-try item. Skaters from kids to adults, from the novices to the seasoned players can try this skateboard truck type. A significant noticing point of Havoc 5.0 Skateboard Trucks is the lightweight. This feature is created due to the material which is aluminum alloy.
Besides, in comparison with many other skateboard trucks in the skateboard industry nowadays, Havoc 5.0 Skateboard Trucks look simpler because of its less details. Another pros of Havoc 5.0 Skateboard Trucks is its variety in colors, such as: yellow, pink, and more, which makes you look more fashionable and attractive. Havoc 5.0 Skateboard Truck has various sizes for skateboarders to choose.
Independent Silver 139mm Skateboard Truck is another option for any skateboarder who is looking forward to the best skateboard trucks with low height. With regard to the material, the Sliver 139mm Skateboard Truck is made of strong and bright Chromoly steel axles. Independent Trucks Silver 139-millimeter trucks are a high-quality, no-frills low-height truck option. Besides, the skateboard trucks support your balance so you can stand more firmly when having a ride.
Next, skateboarders can refer to The Stage 11 Skateboard Trucks. They are also good skateboard trucks with a friendly budget price. The Stage 11 Skateboard Trucks are offered in a set of shiny couple trucks. Not only having a reasonable price, the trucks are well-known for their smoothness when having a ride, long lifespan, and high-quality materials.
Next, we have Independent Stage 10 Skateboard Trucks. When opting for Independent Stage 10 Skateboard Trucks, you will receive a well-drilled baseplate for greater balance and a high center of gravity. The most suitable skateboard trucks which go well with the skateboard trucks have a size ranging from 7.5 inches to 8.5 inches.
Mini-Logo Skateboards 7.6-Inch Trucks is another good option. The skateboard truck is well-known in the market for high-performance skateboard trucks that combine strength, stability, and easy turning. And it's hard to believe that all of this is contained in such a little package.
The Mini-Logo 7.6 inch Skateboard Trucks' qualities are essential for becoming a better all-around skateboarder. This model is great for new skateboarders who are still figuring out how to ride their boards. However, according to some skateboarders, the skateboard truck has a lower ground clearance than comparable vehicles on the market today.
The Speed 5 inches Turbo Skateboard Truck Set with Screws is an ideal choice for all skateboarders. The features of the skateboard trucks come in handy while attempting a tough trick, especially if it's done on the go. One of the most unusual qualities of Speed skateboard trucks is that there is no need for braking because the skateboarder can just spin and grind out smoothly before slowing down.
For newbies, this is critical since fastened trucks provide added strength, stability, and optimum turning capabilities. Furthermore, the baseplate is compatible with the majority of decks recently.
Let’s join the website including a thousand posts and articles about skateboarding: SkateAdvisors - A Skateboarding Blog.The contents of their posts are various, such as tips, guidance, and lists of wonderful skateboards or skateboarding brands on the market.
Follow - Fanpage of SkateAdvisors: https://www.facebook.com/skateadvisors/
