First post, by Boohyaka
- Oldbie
Hi guys,
As I'm missing toying and testing stuff and having read a lot on the subject I'd just like some real-life opinions.
I have a modded P3-S Tualatin 1.4 running on a MS-6905 Master slotket on a P3B-F at 133 FSB. I also have a (currently unused) VIA C3 100x10 1.45V CPU and I want to toy with it with setmul etc.
My chain of thoughts was then to use the P3B-F and slotket with the VIA C3 to play with, and do a "ultimate" Win98 build around the Tualatin. I don't need an ISA slot for that build. So naturally I thought a s370 board would be a good choice for more performance but after reading some more, it seems the 440BX boards performance was still pretty much the same as i815 based boards, even taking into account the AGP2x vs 4x...
So basically my question is, is there a s370 board/chip that would be a noticeable performance increase to build around my modded Tualatin or is my P3B-F already about as good as it can get?
Would the AGP4x actually be able to make a good difference in some cases? Any other reason to look at s370 boards over my current config?
Thank you 😀
